Removing old vinyl overlay
EnFuegoZ28
04-22-2009, 03:46 PM
My Z28 had a rear CAMARO vinyl insert when I bought it. The problem is it is old and falling apart. It is flaking pretty bad. My question is how do I remove the rest without damaging the panel?
TIA
yy
04-22-2009, 08:54 PM
What kind of adhesive or tape was used to apply the ovelays? I'm sure there are better stuff out there but try WD-40 on a small area. It usually works well without damaging the paint. I would let it soak for several minutes and then gently scrape it off using your fingernail or a hard rubber object like those used by window tinters. However, be sure to remove all the shiny nonporous parts first and then apply the WD-40 on the leftover adhesive.
