Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
aftermarket torque arm
Old Jan 12, 2003 | 03:20 PM
charliediss's Avatar
Before my car went to sleep for the winter months it endured a driveline failure that left my rear end in pieces, and destroyed the underbody of my car. One of the victims was the torque arm, which is extremely bent up from the drive shaft smacking into it. Does anyone use an aftermarket torque arm? Can anyone reccomend a good one? Thanks.
-Charlie-
Old Jan 12, 2003 | 03:23 PM
PhantomTA's Avatar
Moderator
bmr
the edlebrock one is nice if you want a stock location one
Old Jan 12, 2003 | 03:54 PM
dreamer1q's Avatar
The BMR one is awesome...plus no more worries about mounting it to the tranny. Which is nice if you swap to a 3 speed like I am doing.
Q
Old Jan 12, 2003 | 04:27 PM
Grover's Avatar
The only problem with the BMR is they don't work with the Kenny Brown Double Diamond subframe connectors unless you get their version that mounts in the factory position.
Old Jan 12, 2003 | 06:42 PM
veech's Avatar
I recomend a spohn torque arm, I am very satisfied with mine. Also it doesnt bolt up to the trans, it hooks up to the cross brace givin the car more traction and a more tied feeling.
Old Jan 12, 2003 | 09:45 PM
MYT30TH's Avatar
I really Like my BMR adj. torque arm, as well as the other BMR items in my sig. .....The car feels & handles Great !!
Old Jan 13, 2003 | 08:10 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Talking
BMR all of the way, everything on the bottom of the car on my car is from BMR so i guess that gives you an idea, lol!
Old Jan 13, 2003 | 10:06 PM
cASe SenSiTive's Avatar
Exposed Member
Definitely BMR. They have two versions, one that mounts to the tranny, and another that mounts to the sub-frames.
All of my suspension is BMR stuff.
KYWes
May 22, 2015 08:48 PM
canbaufo
May 5, 2015 03:43 PM
KYWes
Apr 24, 2015 09:17 AM
Jason Short
Jan 19, 2015 06:34 PM
