bellhousing bolt sizes
z28_theantirice
04-18-2009, 08:04 PM
Currently trying to make sure I have all the hardware for my T56 swap. I need the bolt size for the trans to bellhousing. Also for the bellhousing to the block because I will need 2 more correct?
FYI- I did try and use the search but couldn't find anything.
Spartan7
04-20-2009, 12:39 AM
They are M10x1.5x40. You need 8 of them. You don't need extra bolts for the bellhousing to block. It reuses the same 6 bolts as the auto.
z28_theantirice
04-22-2009, 10:56 PM
1.5 seems a little short? no?
shoebox
04-22-2009, 11:02 PM
1.5 (mm) is the distance between threads. Yeah, it is supposed to be a little short. :D
40 mm is the length.
z28_theantirice
04-22-2009, 11:08 PM
Is this the correct bolt size for the trans to bellhousing ?
Spartan7
04-24-2009, 07:40 PM
Yes, I already posted the correct size.
