How do u add amp to monsoon system?
nillam1
04-18-2009, 11:20 AM
I replaced front & sail speakers with kickers and rears with alpine, sounds good but I would like to add my amp & stealth sub. I have a 200 watt kicker with 10" kicker in stealth box. I purchased the amp wiring kit but how do I splice into monsoon amp for rca's and 12v remote switch on for amp? 2002 Camaro Z28
BandDirector Blk98ZM6
04-18-2009, 09:49 PM
The EASY was is to get a PAC OEM-1 which plugs in behind the HU between the HU's plug and the wiring harness. It'll give you 2 pair of RCA outs w/independent level adjustments as well as an amp turn-on lead. Or, I think there's a wiringing diragram at the FAQ's in this forum, or over at ls1tech.com and you can find the wires to tap.
If you want to go the OEM-1 route, I think I've got a spare one I'd be willing to sell you if you're interested. I currently use one in my system, but I'm pretty sure I have a spare in my garage that I'd be willing to let go.
You can see what an OEM-1 looks like at the link towards the bottom of this page:
http://www.banddirector.cz28.com/photo3.html
nillam1
04-19-2009, 02:15 AM
Thanks! That pac oem 1 makes it a simple install. In the mean time, I ran that 10" stealh sub of my left rear sail speaker and it sounds ok. I will definately be getting the pac oem 1. Thanks again! :metal:
