More Search Criteria
Hal Fisher
04-17-2009, 06:31 PM
I tried to find an answer for this question in every Faq I could find (especially the Search FAQ) but was unable to.
The problem is this: when doing a search if you enter in two words it will give results for both but not necessarily at the same time ie, if you state VALVE PROBLEMS, it will come up with posts or threads containing VALVE and/or PROBLEMS and not necessarily both words VALVE PROBLEMS in the same thread. The option to select Match All Words - Match Any Word - Match Exact Phrase is only available when searching the faq (here: http://www.camaroz28.com/forums/faq.php?). Can a drop down for those criteria be added to the search function?
Hal
