High Temp Powder Coat Needed for Intake?
Hal Fisher
04-16-2009, 06:16 PM
I know if your just painting an intake you'd use high temp paint but I want it powder coated. Is high temp powder coat really needed for the intake? Normal powder coat is good for a little over 300f. I noticed there is a rubber grument (sp?) on the intake that seems fine with the temp it normally reaches. They stated this grument had to come off for the oven process of powder coating. So I figure if the rubber can not handle the oven but the powder coat can than it must be OK to just use normal temp powder coat. Anyone have experience with normal temp powder coat on the intake?
Mr.Whitey
04-18-2009, 07:00 PM
Most powders that I used would be cured around 400deg., so unless you plan on lighting your car on fire you'll be fine using normal powder.
Hal Fisher
04-20-2009, 03:30 AM
I noticed a few on ebay just using the 400 temp as well.
I reasoned that low temp pc would be OK becaue they were making me take the rubber gurment out of the intake so it wouldn't get burned. That proved to me that the intake never gets as hot as the powder coating process so it should be OK.
Hal
hairbear21
05-19-2009, 11:50 PM
Mine has been powder coated in standard powder and it's fine. I've had it on for over a year, and it still looks great.
n2omike
05-27-2009, 12:05 PM
heres mine with normal powder.
This is a very good shop. My buddy owns it but before he did I used them.
http://cfpowdercoating.com/
http://i56.photobucket.com/albums/g190/MikeFitz_2006/My%20cars%20miss/IMG_0097.jpg
http://i56.photobucket.com/albums/g190/MikeFitz_2006/My%20cars%20miss/IMG_1004.jpg
http://i56.photobucket.com/albums/g190/MikeFitz_2006/My%20cars%20miss/IMG_1320.jpg
hairbear21
05-27-2009, 03:53 PM
NICE!
I wish that I had done mine in something other than black, you can hardly see mine.
This is definitely the perfect thing to do to your intake when you're doing the lovely intake leak repair too.
http://i264.photobucket.com/albums/ii188/hairbear21/PowderCoatedIntake2.jpg
