Camarocracy
04-11-2009, 06:29 PM
Ok, so my 97 LTI is hesitating under acceleration. When accelerating from a stop with moderate throttle, the car will hesitate and want to stall.
Last year, we had new headers installed, but used the stock 02 sensors. New plugs and wires were used. Installed a tune by PCM4Less for the headers and new rear gears. We installed a new Walbro fuel pump and filter while we were trying to diagnose the hesitation, the oem was running a little weak. New TPS sensor was installed. Optispark was replaced by previous owner [bought car with 29,999 miles on it in 06, car currently has under 40k].
Ok, on the PCM4less tune, the car hesitated on his tune on the ecm he shipped us, but the car ran fine on the oem tune. So we drove to his place in PA, and he discovered we had a bad ecm [the one he sent us was bad], so he flashed the oem ecm with his tune. But the hesitation came back.
Could it be that the 02's are going bad due to the headers? I know you are supposed to replace the 02's after the header coating kills them, but I have not received a CEL.
Any ideas?
Any ideas?
