New Speakers inferior?
Old Jan 11, 2003 | 08:25 PM
galivan's Avatar
I don't claim to be an audio expert by any means. I don't even qualify as an audio rookie, but I can appreciate good music at higher than average volume, at least occassionally. I just had all the speakers replaced in my 2000 covertible (ie. only 4 6.5 speakers). I have Sony Xplod speakers in my 3000GT and they sound great, so that is what I chose for the Z28. I am unimpressed with the result. Is there a reason that the speakers do not sound as good as the stock speakers did (before I blew them)? I have a Monsoon w/ single disk CD player, if that helps.
The installer is the same one that installed the other set and he swears he put them in correctly. I also had speaker savers and rear dynamats installed.
Thanks for any help.
Old Jan 11, 2003 | 08:30 PM
LS1 RULZ's Avatar
The biggest problem is that the factory speakers are 2ohms. You replaced them with 4ohm speakers which means that they will only be getting about half the power that the factory speakers were getting. That and it takes a lot more than new speakers to improve the POS Monsoon.
Old Jan 11, 2003 | 09:29 PM
galivan's Avatar
So what can I do without spending a small fortune?
I realise that most audio afficianados think the Monsoon is garbage, but I am not planning to replace it, at least not right now. Would a new amp help, if I left the Monsoon and the new speakers as they are?
Old Jan 11, 2003 | 10:03 PM
LS1 RULZ's Avatar
In your case I would get a 4 channel amp and use it along with the factory HU. Make sure the amp you choose has speaker level inputs.
Old Jan 12, 2003 | 08:33 AM
galivan's Avatar
If I buy a four channel amp, would it need to bypass the stock rear amp in the trunk or would it be wired between the HU and the stock amp?
Old Jan 12, 2003 | 09:26 AM
LS1 RULZ's Avatar
The stock POS Monsoon amp won't even be used anymore. Take it out and use it as a boat anchor or something.
You'll run the speaker outputs from your factory HU into the speaker level inputs of your new amp. Then run new wires from the amp to your new speakers.
Old Jan 12, 2003 | 02:13 PM
galivan's Avatar
Thank you very much for all your feedback, LS1 RULZ.
I greatly appreciate it.
Old Jan 14, 2003 | 10:11 PM
galivan's Avatar
LS1 RULZ,
Just in case you were curious, I just went ahead and replaced the Monsoon and had the car rewired. Probably the best bet for potential later upgrades. I went with a Kenwood KDS-419. Not the world's greatest HU, at least as compared to a serious audiophile, but it works fine for me.
Thanks again for the help.
Old Jan 15, 2003 | 05:42 AM
LS1 RULZ's Avatar
Good call. You'll be much happier in the long run with the new setup.
RUENUF
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
football4life
Oct 4, 2015 07:48 AM
Bxlt1
Sep 10, 2015 08:16 AM
tomfric
Parts Wanted
Jul 30, 2015 03:01 PM
