A2W vs A2A
Old Mar 31, 2009 | 08:44 AM
1996camaroSSclone's Avatar
A2W vs A2A
In a drag race setup does it really benefit that much to use an A2W setup? Keep in mind that I am running the formula front bumper so airflow is limited from the front.
Old Mar 31, 2009 | 09:58 AM
boosted-lt1's Avatar
Yes. With air to water you can get IAT below ambient using ice. If an air to air could be built at 100% efficiency, you could only get down to ambient. In reality A2A's are maybe ~70-80% efficient, so IAT will always be above ambient.
-Scott.
Old Mar 31, 2009 | 04:22 PM
TA Dreaming's Avatar
What he said. A2W is great for drag racing not so great for street. Eventually, the water will heat up as well. Does it still work on a street application? Absolutely, Magnachargers are A2W as are all of Ford's SC cars. If air flow to an intercooler is somehow limited, A2W can be better. For a street application though, A2A is better is it can be done correctly with good air flow and the correct size intercooler.
Old Mar 31, 2009 | 08:38 PM
joe-96z1le's Avatar
You can get much lower IATs using A2W, however the system is more complicated and I don't think it's well suited for the street. Another issue, I know of more than one case where the A2W intercooler developed a leak, the water went into the engine, and the motor was badly damaged.
Old Mar 31, 2009 | 11:05 PM
Looks like it's time to start saving the pennies
Old Mar 31, 2009 | 11:28 PM
MikeGyver's Avatar
Salted ice water, or washer fluid and dry ice maybe
Old Apr 1, 2009 | 12:05 AM
The good thing about the A2W is that I found a sponser on tech that works with Chiseled Performance to have the IC made to fit in the nose of the car for ease of installation.
Old Apr 4, 2009 | 06:11 PM
4SFEDZ's Avatar
anyone know what kind of gain you could see goin from a2a to a2w?
RealQuick
Oct 31, 2008 08:18 AM
RealQuick
Oct 23, 2008 09:02 PM
RealQuick
New England Area
Oct 22, 2008 08:16 AM
RealQuick
Oct 4, 2008 09:49 AM
Why Try
Mar 29, 2008 04:34 PM
