steering wheel wobbles
Old Mar 31, 2009 | 12:08 AM
Mr.GearheadZ28's Avatar
How do you fix the steering wheel? Mine moves up and down even with the steering column locked.
Old Mar 31, 2009 | 12:55 AM
MikeGyver's Avatar
If I pulled mine it would bobble up and down too. oh well
Old Mar 31, 2009 | 11:47 AM
OPies57's Avatar
tilt bolts
Old Apr 1, 2009 | 08:33 AM
jraney's Avatar
You need to strip down the top of the column to get to 4 support screws item 61. These loosen up and will cause the steering wheel to move up and down. This only gets worse the longer you wait to fix it. Also make sure that the pivot pins item 39 are fully seated when you reassemble the column. This is not that difficult, just a ton of parts to take off and remember how they go back. To view the items I have referenced to. for an exploded view of the column go to:
http://shbox.com/1/steering_column_exploded.jpg
Hope this helps
jasonduaine
Jun 4, 2015 09:29 AM
CheckOutMyRoost
May 23, 2015 02:33 PM
nikko
Apr 28, 2015 10:05 AM
Airplanedoc
Feb 1, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
