mhilton
03-24-2009, 01:41 PM
Ok, here's my problem; I turn my key on and all the gauges come on. I try to crank the engine and it will not crank, doesn't click or anything, fuel pump doesn't come on either, nor does the security light. I checked my key resistance and my key switch, both are where they are suposed to be at. The car had been sitting for 5 years. I was thinking about changing the computer. I tried to start the car in nuetral and it wont start. I dont think it is the nuetral safety switch. Any help would be awesome.:eek:
70cuda
03-24-2009, 06:06 PM
Check the power at the starter, it should be 12 - 14 volts. Start with that and work your way back up the starting system.
JooneJune
03-24-2009, 10:13 PM
New Battery or an old one?
Clean the terminals of a new battery, check your grounds make sure they are clean and tight. Make sure the motor has fluids... 5 years is quite some time.
I had the same problem. No crank, not even with a jump. Figured something must be bad since battery was only one season old. Charged battery...nothing. Took it back to NAPA and guess what? Bad battery. Put in a new one and it fired right up.
I always thought that a jump would overide a dead battery. From what I read from other posts, if the battery is dead, jump might not get the job done.
teke184
03-26-2009, 09:20 AM
if the battery has a short it generally won't work. i had one that would start with the shorted battery, but wouldn't stay running
mhilton
03-29-2009, 09:27 PM
It's amazing what a pcm ignition fuse will do. Mine was bad, so now my car cranks!! Thanks for all the info.:D
