PAC OEM-1
blue89iroc
07-18-2002, 07:59 AM
Is this the only place to buy one?
http://www.affsave.com/pac.htm
Or are there any cheaper ones out there?
Proud new owner of a 1997 Z-28 M6!!!!! Let the fun begin!
--------FOR SALE---------
1989 Blue Iroc-Z
Edelbrock Headers, High-flow cat, Fastchip, Airfoil, K&N's.
LS1 RULZ
07-18-2002, 08:05 AM
Thats the cheapest I've seen. A place called Tune Town (or something like that) used to sell them for $80. You might have better luck buying a used one. Try asking over at LS1.com
Stoopalini
07-18-2002, 03:22 PM
These guys have the box for $25, but haven't found the 2 interface cables I need yet.
http://www.audiowarehouse.peachhost.com/ct_PR2644971.htm
I am looking to add a sub amp, and will be needing:
1) the PAC OEM-1 unit itself
2) The AMP-RCA cable for RCA outputs
3) The ADD-GM32 cable to interface to my factory Bose HU.
Good luck,
Thomas.
'96 Z28 6-speed
Completely Stock (for now)
LS1 RULZ
07-18-2002, 03:48 PM
You'd better check that Thomas. I think you need the ADD-GM21 for the BOSE interface. Not the GM32.
Stoopalini
07-18-2002, 04:11 PM
Ya know, I was a bit confused on that; because I found info that said the ADD-GM21 was for years up to 94 (or maybe 95?) and the ADD-GM32 was for my '96.
Is this not correct? If not, I'm glad I found out now instead of after I ordered them http://web.camaross.com/bb/smile.gif
Thomas.
'96 Z28 6-speed
[This message has been edited by Stoopalini (edited July 18, 2002).]
Stoopalini
07-18-2002, 04:35 PM
I just did a bunch of searching, and you are correct. It's the ADD-GM21 cable I need.
Thanks for pointing that out.
FYI: Check out this Sub Install (http://www.horist.com/Subwoofer%20Install.htm) using a PAC OEM-1 unit page I found; it looks like some good info.
Thomas.
'96 Z28 6-speed
