trekin9700
03-19-2009, 06:46 PM
Im replacing my ECM, and found one for an A4. I was wondering if it will be compatible with my car being how it has the T56. the ECM is for a 93 and my car is too. Thanks in advance for any insight you might be able to provide.
shoebox
03-20-2009, 08:06 AM
Idle speed is different between the two transmissions and there will likely be some other subtle things. Better to get the one for your setup, IMHO.
rskrause
03-20-2009, 08:20 AM
The PCM is identical. There are a few minor differences in the tune.
Rich
trekin9700
03-20-2009, 06:47 PM
Whats the difference between the PCM and ECM?? Isnt the PCM on the back of the seeedo Cluster?
trekin9700
03-20-2009, 07:03 PM
would an ecm form a lt1 Vette with a M6 tranny be identical too??
shoebox
03-20-2009, 08:37 PM
The computers changed from ECM (Engine Control Module) in 1993 to PCM (Powertrain Control Module) in 1994 and later (adding electronic transmission control). Though 1993 and 1994 were both OBD-I, they used different computers. 1993s used the replaceable chip type (PROM), while 1994 and up used flash memory for storing the program (EEPROM).
94-95 Corvette PCMs are the same as the 94-95 F-body PCMs.
trekin9700
03-20-2009, 10:32 PM
i was scanning my car with a snap-on solus pro, and it said my oil temp was -32. Do these cars even have oil temp sensors??
shoebox
03-20-2009, 11:16 PM
No. Disregard.
trekin9700
03-31-2009, 07:23 PM
Got the ECM. Just put my old prom in, and it's working good so far. Since i put the old prom in, do i need to have it tuned? I know if i used the A4 prom i would.
