2nd_chances
03-18-2009, 10:00 PM
Current set-up is Jet-Hot(Hooker) long tubes and ORY to a Magnaflow
cat-back. The Y-pipe needs to go! It has been a leak issue from day one because of it's fit and alignment issues.
What are the altenatives out there? The Stainless Works one looks like it can be worked with a little for trimming and fitting. Also considering just having a custom shop make one, possibly with cats.
What has worked for everybody?
silentsprintero
03-19-2009, 09:53 AM
I had Pacesetter ORY on my last Z and my current Z and it has worked just fine. They clearance it to fit up tighter to the body.
JakeRobb
03-19-2009, 09:56 AM
Usually, you need to have the Y pipe that is made by the same company that made your headers. The collectors aren't in exactly the same place from brand to brand, so you're likely to have fitment issues if you mix and match.
Call up Hooker and tell them your Y-pipe leaks. They'll fix you up. :)
2nd_chances
03-19-2009, 10:03 PM
I can't imagine the fit getting much worse than it is with any brand. Out of the box the C/L of the headers to the C/L of the y-pipe dimension was off at least an inch. After some cutting and fiddling it's pretty close, but it's still out of square.
BlackBird97
03-19-2009, 10:25 PM
I like my mufflex Y pipe. 3in piping all the way to the 4in Y collector. Flow baby flow :)
2nd_chances
03-20-2009, 08:39 PM
Still wondering if anybody has experience with the stainless works y-pipe for LT1?
93BlackTA
04-05-2009, 09:29 PM
I would like to know this as well....my hooker LT's leak at the hooker Y-pipe as well and had to be cut and welded to line up...It still leaks and i am also looking for an alterative...Would the pacesetter y-pipe work i wonder?
bobdec
04-06-2009, 10:40 AM
This may help.. The Pacesetter Y-Pipe attaches to the Pacesetter header 3 inch OD collectors 28 inches center-to-center apart and just about 4 inches from the back of the A4 transmission pan. That's about 14 inches forward of the pass side CAT mounting hanger. The front of the 2 Y's are 3 inch ID and slip over the collector and the rear Y is 3 inch OD ending about 5 inches behind the tunnel brace where it meets the CAT back exhaust pipe in the center of the car. The driver side of the Y pipe has a flat section on top to clear the protruding floor pan support and the fuel lines.
