SLP Craftsman stubby spark plug socket
mrmint69
03-10-2009, 11:05 PM
I have Pacesetter Mid headers. I had someone else try to pull my back drivers plug and they could not get it without this. He's been a certified tech for 12 years and none of his tools or tricks worked. It fits on and you use a 19mm wrench to loosen it. This thing is a real life saver.http://store.summitracing.com/partdetail.asp?autofilter=1&part=SLE%2D30102&N=700+115&autoview=sku
Spartan7
03-10-2009, 11:13 PM
I use one of those too. That and a ratcheting box end, makes it a whole lot easier.
Injuneer
03-11-2009, 12:45 AM
SLP is basically buying a less-than-$5 5/8" spark plug socket, cutting it down, and charging you $30 for it....... think about it. You could do the same thing with a Craftsman socket and a hacksaw.
mrmint69
03-11-2009, 01:09 AM
I think the price is crazy but don't think outside the box like you. I now will buy a hacksaw and make my own if I lose this one.
madhatter
03-11-2009, 02:37 AM
Get the cheapest one you can. You will also have to drill out the socket drive.
BTC
03-11-2009, 05:43 PM
I used a socket that I believe was a 1/2" drive, and a pair of vice grips.
PoorMan
03-18-2009, 07:53 AM
They did something similar with are Z28s and TransAms. They just did some simple boltons and called them either a SS or Firehawk. Did it myself and safed alot more than $30. ;)
josh77888
03-30-2009, 09:41 PM
just buy a set of Go-Thru sockets. Local advance auto parts has a full set for 15 bucks. works great for that and other projects.
caldercay
04-18-2009, 10:17 AM
You mean, like this? :)
http://picasaweb.google.com/calder.cay/Z28#5191820472584205154
I made that to use after installing the Kooks.
Fuels94TA
04-18-2009, 11:25 AM
I made mine about 2 years ago and love it...
Injuneer
04-18-2009, 10:52 PM
I have a "collapsing" socket from The Eastwood Company - not sure if they make it any more. Its has three telescoping sections that allow it to collapse to 3/4" to get it over the plug. Than as you push it down over the hex on the plug, the upper sections pop out, and each has a hex on it that can be turned with a wrench.
