Computer/Electrical Problem
Mehunt87
03-04-2009, 10:18 PM
I have been searching the forums and noticing many people having the same problems that I am. I have a 1996 Camaro and recently it has stopped running. The dome lights do not turn on when I open the doors, and there's no sound when the key is in the ignition recognizing no seat belts/door open. When I attempt to turn it over i get nothing. I thought it may be the VATS and did a bypass using the correct ohm resistors and it had no effect. Then I read another post describing some of my other "symptoms" the clicking noise from the glove compartment, and they had mentioned it may be a BCM problem. Long Winded narrative short, I have replace the battery, which seemed like it was going to work but after a failed start up attempt, it went back to nothing. Recently I installed a new stereo/amp/speakers and was wondering if anyone had any advice or could point me to some links that may help me.
Much Appreciative,
Trevor
