1996camaroSSclone
03-02-2009, 06:23 PM
Will one of these get me buy until I can afford an aftermarket ecm? advantages and disadvantages? Is this a good one to maybe try? http://www.exoticperformanceplus.com/performance_parts/index.html?item=1103 looking to run 96# injectors.
Injuneer
03-04-2009, 01:09 AM
Here's one that other LT1 owner's have used:
http://www.acceleronics.com/versafueler.htm
mzgp5x
03-08-2009, 10:28 AM
I am using the Acceleronics converter. Also LJ's Semens 72# injectors.
The peak-hold driver helps make the engine revs very "snappy." You can also run stock type injectors with it also. I have run this for 5+ years now. I had trouble with the initial driver (bad ground), but, LJ was very cooperative and replaced/ fixed the unit promply. I've looked into aftermarket speed density units, but, they are expensive, and, required alot of changes for ignition timing.
AF_market systems do have advantages over use of the stock PCM for programming, and, I think it is simpler to program. I use LT1_edit ver. 2.2, and, do my own program flash with help of a DynoJet O2 tool. B.
