95 3.4L, OBD '1.5' - Can't get scan tool to connect
Dave_A
02-25-2009, 09:03 PM
95 with a 3.4 V6.
OBD II Connector, I assume this is an 'OBD 1.5' vehicle'???
Borrowed a CanOBD 1 & 2 (innova) scanner from Shucks, and it fails to connect...
What scanners work?
I would preferr not to mess with 'paper-cliping' codes....
shoebox
02-25-2009, 09:28 PM
Wow, I did not realize that the 3.4 had the same DLC as the LT1. You just need the correct adapter cable for an OBD-I scanner or adapt a 12 pin cable like this (http://shbox.com/1/xraycable.jpg). You couldn't flash codes with a paper clip, anyway.
