1996camaroSSclone
02-24-2009, 09:21 AM
Where did all of you get your cam for your turbo setup and for how much? Custom or shelf grind?
cam for a turbo?1996camaroSSclone 02-24-2009, 09:21 AM Where did all of you get your cam for your turbo setup and for how much? Custom or shelf grind? jsetzer 02-24-2009, 10:45 AM I say cam it like you want it to drive - There are "ideal" cams, but the turbo will make power either way. Look up Speed Inc's car when they had the lt1. He did a lot of cam swapping and found that every time he went to a bigger cam (even ones with more overlap that suggested for boost) he made more power - Just at a higher rpm range. Well guess what an NA car does with a bigger cam. If you want to spin it to 7k, get a cam that will do that. I have a 218/224 112lsa cam - technically I still have a little bit of negative overlap, but between the baby cam and tiny turbo I only spin it to 5500-5700ish at most. 1996camaroSSclone 02-24-2009, 02:43 PM I'm looking to spin it to around 6500. I don't really care to see 7k. jay_rich 02-24-2009, 03:03 PM mine was custom spec'd by comp cams 230/236 .544/.555 on a 114LSA (all on 1.6RR) comp grind#lt1 3315/3316 HR114.0 Took them 3 business days top my door in canada! Jay 1996camaroSSclone 02-24-2009, 03:09 PM mine was custom spec'd by comp cams 230/236 .544/.555 on a 114LSA (all on 1.6RR) comp grind#lt1 3315/3316 HR114.0 Took them 3 business days top my door in canada! Jay How much was it? jay_rich 02-24-2009, 04:35 PM How much was it? I think it was 302us shipped to my house. I dont think they charge shipping. Also tell them u need the long dowel for the vented opti. They put the wrong one in mine. Jay boosted-lt1 02-24-2009, 06:56 PM Jay, How do you like that cam? Thanks, Scott. RealQuick 02-25-2009, 11:03 AM I had that same cam in my N/A setup stock bottom end... 383rwhp @ 6000rpm / 353rwtq @ 5300rpm. I liked it. http://memimage.cardomain.com/ride_images/1/1513/1161/3780580045_large.jpg jay_rich 02-25-2009, 06:00 PM the cam hasnt been run yet. I am still in the process of building my hot side. Jay 1982z28with18s 02-25-2009, 08:29 PM I had that same cam in my N/A setup stock bottom end... 383rwhp @ 6000rpm / 353rwtq @ 5300rpm. I liked it. http://memimage.cardomain.com/ride_images/1/1513/1161/3780580045_large.jpg Holy crap, I forgot about that setup, but I remember now you posting about it a lot back in the day. :eek: reamo04 02-25-2009, 09:45 PM I had that same cam in my N/A setup stock bottom end... 383rwhp @ 6000rpm / 353rwtq @ 5300rpm. I liked it. http://memimage.cardomain.com/ride_images/1/1513/1161/3780580045_large.jpg holy facking torque, i bet that was fun to drive jay_rich 02-25-2009, 10:43 PM My N/A setup did 411RWHP@6080rpm and 396RWT@4500ish RPM....it was fun to drive. Mash the gas at 80kmph and feel the backend kick out. Merging on highways was fun :) Jay RealQuick 02-27-2009, 02:21 PM Yeah, it seems like it was so long ago! That was back in 2003... and a few months later I tore it down for the big build. Never got a chance to get it back together. The tq was great... those numbers were with LE stage 2 heads from 2003. boosted-lt1 02-27-2009, 04:46 PM Cool. I'd like to see how it works with a turbo. What did you guys think of the street manners/drivability/sound? Thanks, RealQuick 02-27-2009, 04:51 PM Cool. I'd like to see how it works with a turbo. What did you guys think of the street manners/drivability/sound? Thanks, It had a good lope to it (probably a 5 on a scale of 1-10). Powerband was perfect IMO. It would buck below 1500rpm until I got the tune worked out, then it pulled pretty smooth down low. 1982z28with18s 02-27-2009, 05:13 PM How fast are you wanting to go? Anything under 135mph, just use a stock cam and lt4 springs. RealQuick 02-28-2009, 09:23 AM How fast are you wanting to go? Anything under 135mph, just use a stock cam and lt4 springs. Justin, he is getting a T88 header kit from me, so hopefully he can get in the 145mph area. reamo04 02-28-2009, 10:39 AM well, engineermike likes to recommend a 230/236+4 i would call cammotion and get a custom grind. they know what they're doin RealQuick 02-28-2009, 10:58 AM Mike has gone 146mph w. 224/2236 and T76 slomarao 03-01-2009, 09:21 PM What about Jose at forcedinductions.com? | ||
