Compression Ratio???
BLWNLT1
02-23-2009, 04:23 PM
How do you figure out what compression ratio you will have.
ak95ta
02-23-2009, 04:30 PM
http://www.camaroz28.com/calcs/index.shtml
That and more.
boosted-lt1
02-23-2009, 05:58 PM
Yup. Just find a calculator you like using.
It's also important to understand fundamentally what a static comp. ratio is so that you know how stroke, gasket, piston relief, piston deck height and chamber cc changes affect the ratio.
CR is volume above the piston at BDC divided by volume above the piston at TDC - or a volume ratio.
The only thing I noticed in the the link to the one on this site is that it doesn't take into account gasket bore dia. separately. For a Felpro 1074, the gasket dia. is 4.060", so you cant assume that dimension is simply bore diameter.
I've been using this one lately:
http://www.csgnetwork.com/compcalc.html
-Scott.
