az1gplus
01-09-2003, 03:06 AM
Thanks ahead of time for anyone's input/$.02 worth.
I have had my 4.10:1 Richmond gears go south for the second time in 6 months. I had the first set installed by a friend because I didn't have the time to do it. He did a great job, and I certainly trust his work (ASE certified master tech). The second set I installed my self using all of the proper GM tools such as the pinion depth gauge, and dial indicator for setting backlash. I know they were installed within .002" of spec. on the pinion depth, and .001" on the average backlash. The housing is straight and good, the bearings are good with normal wear patterns. The first set of gears, one tooth broke off of the pinion gear. I was not under heavy load (doing only 25-30MPH) when it happened. The second set, TWO teeth right next to each other broke off of the pinion, also occurring under low load. On both occasions, the teeth have an interresting break in them. You can see the grain in the metal, like it was already weak. I DO NOT use slicks on my car, and I have been to the dragstrip a total of 3 times in the 6 months I had the 4.10's. It is a stick car with the normal bolt ons. Not that powerful.
So, now that I have written my life story, what is the best gear set made for the HORRIBLE 7.5" rearend? Brand/additional parts recomended/fluids/break-in procedure/etc.? I want to make sure that this set lasts a little longer. Strange gears were recomended, but I also see a lot about the Motive gears. What is your experience with any of these brands in a 4.10:1 ratio? I know any lower gear would be stronger, but I can deal without the performance of the 4.10's.
I WILL say that Sumit Racing has been GREAT through this whole ordeal. They exchanged the first set after 126 days of use , and the second set after 117 days of use. They carry a 90 day warranty, but honored it anyhow.
Thanks again,
Cole
Thanks again,
Cole
