Ta4life
02-19-2009, 05:57 PM
i have 4 chan i guess since i have 4 brake lines and 2 from master after module was taken out.
what size brake lines are these so i can get my T's and fittings
camarobird92
02-19-2009, 08:44 PM
They are metric lines and fittings. Good luck finding metric stuff. I cut the stock fittings off and put on new standard flare fittings. I forgot the exact size though. I think 1/4" for the small lines and 3/8" for the large line. Mine is a 3 channel though. You might only have the small size lines. There is a pretty good write up here about it. Search around a little and you should be able to find it.
Ta4life
02-19-2009, 08:56 PM
i planed on cutting flares off to neaten it all up :D
so cut pieces off and prob just take it to store to figure out what sizes ima need and get T's that fit
jakesz28
02-19-2009, 08:57 PM
Here is a little something I wrote up. http://www.jakesz28.com/ABSdelete.html
