Boost controller?
1996camaroSSclone
02-17-2009, 03:32 PM
Would I be better off to run a boost controller if the car is strictly drag? If so what are some good ones to choose from?
reamo04
02-17-2009, 04:50 PM
if its strictly drag, just throw in a higher PSI wastegate spring
mn_vette
02-18-2009, 10:10 AM
If this if for draging I would look into the EBOOST2 controller. Its an electronic boost controller and it has alot of nice features. Things like selecting a boost level based on rpm, gear selection, or time. It also helps keep the wastegate closed instead of just keeping the boost reference from getting to the gate.
Also having an electronic boost controller will help with quick and easy adjustments if you end up getting to a track that isn't properly prepped.
http://www.turbosmartonline.com/index.php?id=42
Download and read through the manual.
jsetzer
02-18-2009, 11:19 AM
Either of the above ideas are good. I have the cheapo ebay $5 one and its kind of crappy. I can run more boost than my spring is rated for, but its never reliable, I see different boost levels fairly regularly.
1996camaroSSclone
02-18-2009, 03:02 PM
I'll have to look into it. Thanks for the help.
1982z28with18s
02-19-2009, 08:22 AM
Joe P makes a really good manual boost controller, google it.
