cboggs5
02-13-2009, 04:09 PM
Need info on headers
I WAS THINKING OF BUYING SOME PACESETTER HEADERS AND WAS WONDERING IF THEY WERE A GOOD BRAND THIS IS THE INFO ON THEM
Manufactured using mandrel-bent, mild steel tubing and surface-ground, thick steel flanges, PaceSetter Headers are available with standard black painted finish or Armor*Coat, a polished, 2000 Degree F, metallic-ceramic coating. Each header undergoes an extensive preparation phase followed by two applications of the coating and a high-temp curing process. The Armor*Coat won't discolor like paint, chrome or dull finish coating, reduces underhood temperatures, resists rust and corrosion and is easy to keep clean. All PaceSetter Headers come with hardware, gaskets and illustrated instructions and are backed by a three-year warranty. Header bolts not included.
Quality Manufactured in the USA and affordably priced
CNC-machined 3/8" think steel flanges are matched to exhaust port profile for optimum seal and flow.
Flash-controlled 16-gauge carbon steel primaries provide greater durability than light gauge stainless steel.
Length and diameter of mandrel-bent tubing is optimized for flow and best performance increase.
One-piece design installs easier
Complete with necessary gaskets and fasteners for installation
Header Type: Full-length
Tubing Diameter: 1-3/4"
Collector Diameter: 3"
