wrd1972
02-13-2009, 12:30 PM
I have a front LS1 brake caliper that drags a good bit more than the other. I think this stemmed from me bead-blasting it in the bores before I realized I was doing something bad to prepare it for finish. The caliper is powder coated so I want to save it if possible and not replace it.
I have had it apart several times looking for piston bind but I cant find any. The two pistons easily slide in and out of the bores with no binding at all and there is no bead present. The two seals appear fine too. What else could cause this?
Maybe I should lightly hone the two bores and replace the hose.
Any thoughts?
4THGEN Z
02-13-2009, 02:01 PM
Are the guide pins well lubricated?
wrd1972
02-13-2009, 03:19 PM
Very well lubed up. :yes:
NJ-LE
02-13-2009, 05:14 PM
wrd1972:
Sounds like you have rebuilt the caliper well, You might check the run out to see if the rotor is a little warped, also it's possible that hub's bearings are worn.
transAMdriv3r
02-14-2009, 08:25 PM
what makes you think its dragging? is it pulling to one side or excessive heat ? I'm thinking because you cant find anything wrong with that caliper maybe the other side is not functioning.
just a thought...
~Greg~
wrd1972
02-16-2009, 09:22 PM
wrd1972:
Rotor is brans new and NOT warped.
just a thought...
~Greg~
Jacking it up, it is much harder to turn the left wheel by hand compared to the right wheel.
transAMdriv3r
02-16-2009, 10:07 PM
oh, mabe a wheel bearing as nj-le has said? if a wheel bearing is bad it will cause the rotor to lay against the caliper.
wrd1972
02-17-2009, 09:01 AM
I will check that.
transAMdriv3r
02-22-2009, 03:07 PM
I will check that.
so how'd you make out ?
wrd1972
02-22-2009, 09:18 PM
Aint got to it yet. Most likely will wait to spring.
95TA04GOAT
03-05-2009, 10:20 PM
When you have the front end up and are spinning the tires, try cracking the banjo bolt on the caliper that seems to be dragging. Doing so will eliminate the hose as a suspect. If it spins more freely the hose needs to be replaced, if not, the problem is elsewhere. I bet it's the hose, if not, maybe the piston seals. I've read that they act as a spring and pull the piston back slightly once brake pressure is released.
