Timing reduction issue
95Blackhawk
02-13-2009, 06:52 AM
All,
Reprogrammed my car to reduce timing when the coolant got above 92 C as an experiment. On the table, I took out 4 degrees but upon using Datamaster, it showed anywhere from 11 to 8 degrees taken out. This is approximate because I have not analyzed at what RPM, etc. that each differnet timing was taken out.
Bottom line: seems the mystery timing was also taken out but that doesn't exactly correlate either.
I have reprogrammed to what I had before but have not datalogged as of yet.
What am I seeing?
MikeGyver
02-13-2009, 11:59 PM
Tunercats? which table did you modify? ...keep in mind that lots of other tables are referenced as modifiers so it can be annoying to figure everything out.
95Blackhawk
02-14-2009, 06:59 AM
Yes, TC.
Modified the coolant vs map table.
Thank you,
Ben
