reamo04
02-13-2009, 12:20 AM
wondering how I would go about replacing the bolts on stock manifolds?
How to replace manifold studs?reamo04 02-13-2009, 12:20 AM wondering how I would go about replacing the bolts on stock manifolds? MikeGyver 02-13-2009, 02:18 AM huh? Just a guess but, unscrew old bolt, screw in new one? :D reamo04 02-13-2009, 02:44 AM huh? Just a guess but, unscrew old bolt, screw in new one? :D well, idk, its almost like their stuck in there and spot welded or something...are these reverse threaded perhaps? Wild Willy 02-13-2009, 07:37 AM Exhaust manifolds? They can be difficult- they tend to rust out. I have had best luck doing them while hot- you need to wear welders gloves, but the heat loosens the corrosion. Otherwise, heat them with an acetylene torch- propane isn't going to throw enough heat- get them glowing cherry red, and they come right out- If they snap off, take the whole manifold off- there may be enough of a stub sticking out, if you are lucky, to get them out with vice grips- otherwise, it can get real ugly- reamo04 02-13-2009, 12:06 PM Exhaust manifolds? They can be difficult- they tend to rust out. I have had best luck doing them while hot- you need to wear welders gloves, but the heat loosens the corrosion. Otherwise, heat them with an acetylene torch- propane isn't going to throw enough heat- get them glowing cherry red, and they come right out- If they snap off, take the whole manifold off- there may be enough of a stub sticking out, if you are lucky, to get them out with vice grips- otherwise, it can get real ugly- yeah i have them off the car, so that'll be easy enough to do. Thanks guys. MikeGyver 02-13-2009, 09:42 PM lmao ohh are you talking about the 3 studs in each manifold? I thought you were talking about the manifold to head bolts... I replaced the 3 collector studs on both my manifolds since they bent to hell. I heated up the cast iron around the stud with a vutting torch, and simply unscrewed them with a big crescent wrench. I used a cutoff wheel on the back side to flatten the shoulder so I could TIG weld the appropriate sized bolt in place, after drilling the threads out. I also over sized the 3 holes in each collector flange so it slides over the 3 studs/bolts easily without binding. | ||
