TasTe GOOD
02-07-2009, 12:07 AM
I'm going to be installing 2 V-band clamps at the end of my Slp Mid Headers and I was wondering, do I need to install some sort of flex pipe on the Y-Pipe? If so, where?
The reason why I am putting v band clamps on is because one bolt hole on the 2-bolt ball and flange is stripped (driver side) and one on the passenger side siezed as I tried to loosen it up.
Because of the stripped 2-bolt flange, I am getting a real bad leak, causing me to get headaches and bad o2 sensor readings (I am assuming from what I have read about header leaks and ses light I am getting after install...)
