Chevycobb
01-31-2009, 02:38 PM
New clutch installed, shimmed flywheel(guy machining recommended it), bolted everything back and fired it up... then noticed the grinding sound when clutch is fully pressed. :mad:
I am assuming the fork is hitting PP by going off of some searches on here, and the shim might be possible to blame.
Before I go back downstairs after cooling off from frustration, can the bolt holding the fork in places be reached by just sliding the fork out, with out pulling back the trans? really not wanting to unbolt everything again :(
edit: nevermind. found someone asking the same thing and everyone said you couldn't :(
