Do I need LS1 brake lines for LS1 front brakes conversion?
MysticTeal95Z28
01-31-2009, 10:23 AM
Hey guys, I am looking into doing LS1 Front Brakes on my '95 Z28. I found a '98 T/A in a junk yard with the front-end intact (wheels are still on it even) and I can get everything I need from it.
My question is do I need the brake lines off the '98 T/A or from another LS1 f-body or can I use the brake lines that are on my '95 Z28?
Thanks!
94ZBlk
01-31-2009, 09:22 PM
I've read here that you can use the LT1 lines, but have to bend the brake line bracket for them to work. I'm in the process on doing the upgrade now. I have the Earl's SS lines for a LT1, so I'm hoping I can bend the brackets and still use them.
TitoPR221
02-01-2009, 09:45 PM
I'm doing the conversion also. The brake lines are different. I would not bend the bracket, I plan to order 98+ lines with 2 extra inches length to prevent damage.
Don 97 SS
02-01-2009, 10:59 PM
I did the 98+ brake upgrade almost 8 years ago. I bent the oem brackets slightly and reused my oem brake lines. It has worked perfectly since then. :DAs I recall the 98+ brake lines did not have the correct shaped fitting to 'lock' into place and secure the lines to the bracket.
4THGEN Z
02-04-2009, 12:21 PM
I used 2000 C5 Corvette front brake hoses and they provided the perfect amount of slack without any modification to the hard lines. Did the conversion in 2003.
TitoPR221
02-05-2009, 09:41 PM
Did you purchase them new OEM ? Do you have part numbers?
MysticTeal95Z28
02-06-2009, 11:35 PM
Well guys I went down to the junk yard today with my Dad and we pulled everything associated with the front brakes on that '98 T/A including brake lines for $ 100.
It worked out awesome, I'll be gathering up more of what I need here in the near-future to do the swap. ( i.e. brake pads, sand blasting & painting stuff, etc. )
4THGEN Z
02-07-2009, 12:17 PM
Yup, OEM, just went to the dealer and asked for front brake hoses for a 2000 Corvette....sorry I don't have the p/n handy.
Here's a pic though:
http://www3.sympatico.ca/splt1/Uploaded_files/StewZ/LS1%20Brakes/full_lock_left.jpg
