canuck94z28
01-29-2009, 02:57 AM
I will be installing a Vig 2800 stall in spring and need advice on a few things.First do i need one and what brand do you guys recommend?Guys that have Vigilante stalls would be most helpful.Thanks.
Trans coolercanuck94z28 01-29-2009, 02:57 AM I will be installing a Vig 2800 stall in spring and need advice on a few things.First do i need one and what brand do you guys recommend?Guys that have Vigilante stalls would be most helpful.Thanks. Z-RATED94 01-29-2009, 10:55 AM I had a Vig 2800, nice converter. I then went with a Yank SS3600, again, nice converter. Pick up a B&M Supercooler and tie that into your trans lines. Run the factory cooler first and then through the B&M and back to the trans. I do run a 160 thermostat, and would recommend the same if you don't already. canuck94z28 02-01-2009, 01:23 AM Thanks for that reply.Do you remember the price,part no,where you bought it? IROCET 02-08-2009, 02:44 PM I have a Hayden cooler on mine. I got it at Advance Auto for about $60 I think. Most parts stores should have them. I don't remember the part number of the one I have. I have had one on two different cars and both times have gotten the one that is rated "Heavy Duty" or "Extra Heavy Duty". You would be surprised how hot the tranny fluid gets even on a stock car. canuck94z28 02-10-2009, 02:19 AM I found one in Summit,catalog.It,s a BM#70268,price is 49.95.Can anyone verify this,has tried it,etc. canuck94z28 03-14-2009, 01:26 AM I just ordered one yesterday.I got one of Summit,s own brand w/ Gvw of 18,500 and one of the best things about it was that it was made for tight engine compartments,yet still cools like the bigger sized. 94Sleeper 03-14-2009, 01:53 PM I would also recommend the Hayden coolers. They are only 3/4" thick and fit well in the confined area front of a 4th gen F-Body A/C Condenser. Best place I found them is: Hayden Coolers (http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=2&Category_Code=hayden-transaver) I use the 1679 model and it fits very well. I would also suggest getting a set of hose splices to install your cooler: Hose Splice (http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=2&Product_Code=13028&Category_Code=cooler-fittings&Product_Count=4) These splices are for 3/8" hose and the GM hose I believe is 11/32". They will be tight but should work well. canuck94z28 03-21-2009, 02:47 PM I would also recommend the Hayden coolers. They are only 3/4" thick and fit well in the confined area front of a 4th gen F-Body A/C Condenser. Best place I found them is: Hayden Coolers (http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=2&Category_Code=hayden-transaver) I use the 1679 model and it fits very well. I would also suggest getting a set of hose splices to install your cooler: Hose Splice (http://www.bulkpart.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=2&Product_Code=13028&Category_Code=cooler-fittings&Product_Count=4) These splices are for 3/8" hose and the GM hose I believe is 11/32". They will be tight but should work well.The one i bought is 3/4 thick w/1/2 tubes and is17x7 1/2x3/4.Thanks for that info. | ||
