White X on flywheel and yellow dot on pressure plate....
ACE1252
01-24-2009, 02:00 AM
Question....
Here is the white X on my old flywheel and the yellow dot on the old pressure plate....fairly cut and dry on which hole to line them up....
http://www.ace1252.com/images/old_flywheel_white_x.JPG
So which hole do I go with here on my new flywheel and new pressure plate???
http://www.ace1252.com/images/new_flywheel_white_x.JPG
I guess I just pick one and try it.....and experiences or comments on this???
PoorMan
01-24-2009, 05:21 PM
I would take it back to the store and have them pull another one.
ACE1252
01-25-2009, 12:29 AM
Well, I've just put everything back together. I put the red mark on the right side of the white X(just like in the above picture). My test drive had a bad vibration start around 4500 and go all the way to redline. :rolleyes::mad::mad::cry::cry:
I'm going to call Valeo Monday and ask them about the yellow dot and what it means. I hope they have some info for me. Otherwise, I may have to pull this tranny up to another 5 times.....rotating the pressure plate around the flywheel until the vibration goes away(if it goes away with this pressure plate).
I'm also going to ask them about this Autozone knock off pressure plate and how it stacks up to their pressure plate. I will post up what they tell me.
Green96Z
01-25-2009, 12:44 AM
When I did mine, I got a replacement flywheel from AZ, but it didn't have a mark on it. What I found by searching was to put the yellow mark (which is for balancing by the way) as close to the flywheel locating pin as possible.
Chevycobb
01-27-2009, 11:35 PM
^ I sure hope so, that's how I just bolted mine up anyway
ACE1252
01-28-2009, 08:40 PM
I do have some more information.
I called Valeo and their tech support confirmed that the marked side(yellow dot) of the "LT4" pressure plate is the LIGHT side of the plate. I do remember seeing this info on the board somewhere, but this confirms the info.
They had no information on what the white X means on the LT1 flywheel. He said he could speculate, but didn't want to as not to tell me wrong.
He said that Valeo checks the spin balance of their plates and the spec is 20 gcm max.
I did take the Duralast plate and spin it 180*. So the red mark is opposite the white X on my flywheel. Upon my test drive, the vibrations were much worse. They started at 2000 and magnified until I stopped at 4500rpms(too scared to go any higher it was so bad). They were so bad that I could not only feel, but hear the out of balance condition at 2000 rpms and on up.
Tonight I'm going to pull the tranny again....I have gotten so good at this I can have it out in about an hour. I'm not sure if that's good or bad.:think::think:
I'm going to try and see if I can feel the vibrations with the tranny out of the car and the pressure plate bolted up. My gauge has been how much vibration I can feel through the shifter stick, so I don't know if I will be able to tell too much(but I know when it's right). If I can't work this out, I plan on buying a genuine Valeo LT4 plate.
I know that I'm not the first to post up complaints on the balance of the Duralast plate.
Heck, I may ask Valeo if I can ship this Duralast plate to them for testing. I'll be glad to pay them to test it....just to see how balanced it is.....
Chevycobb
01-28-2009, 09:09 PM
im guessing the duralast is the Chinese version?
where was it in relation to the locating pin? I haven't finished mine yet. I can't seem to find one of the trans. to bellhousing bolts :mad:
ACE1252
01-28-2009, 10:20 PM
Just got the tranny out.....took 40 mins....lol.
The white X on the flywheel can be anywhere around the flywheel. It is in different spots on the two I have....and I have a third stored in my attic(actually it's the first one....the one in the top pic is 2nd, and the lower pic is 3rd...the one I just bought). I wished I could say for certain what the X on the flywheel means, but I can't.....and there is nothing mentioned in the factory manual about it.
The only thing I know for certain about the flywheel is that the weights on the old one must be transferred to the new one in exactly the same positions(referencing the location pin).
The mark on the pressure plate can be yellow, white, or red. Those are the different color markings I have seen.
Chevycobb
01-28-2009, 10:35 PM
damn, now you got me doubting my install. guess we'll see how it goes when I stop being lazy and finish it. I remember mine a long time ago having that X on the flywheel, but didn't even think to look where it was supposed to be on it now, because there is certainly no X on it anymore. guess it wore off
Green96Z
01-29-2009, 04:21 AM
I think the weights on the pressure plates are for zero-balancing, which the PP SHOULD be. Take it to a machine shop and have them balance the PP. A seriously out of balance one would definitely give you a vibration, no matter which way it faces.
Another thought on the marks on the PP and flywheel are that maybe the PP is weighted opposite of the mark on it, so that when the marks are aligned, the weights on the PP somewhat counterbalance the weights on the flywheel (since the flywheel has weights on it to balance the crank). Just a thought. Either way, I would definitely avoid putting a cheap "Made in China" pressure plate in mine, and stick with the Valeo.
ACE1252
01-29-2009, 02:14 PM
I've located an Automotive Machine shop in Greensboro that can dynamically balance flywheels.
The pressure plate has no weights on it(neither the Valeo or Duralast). The flywheel does(the ones you transfer from your original flywheel).
I'm going to remove them and have the shop spin it up to see if the white X denotes a heavy or light side of the flywheel. Once we know where we stand with the flywheel, they are going to bolt the pressure plate to it and spin it up.
I'm dropping them off tomorrow, so I may not know anything until next week.
ACE1252
01-30-2009, 10:30 PM
I dropped both the flywheel and plate off today and learned something from him that was actually staring me in the face.
http://www.ace1252.com/images/flywheel_pic.jpg
These flywheels are not neutral balanced from the factory(for some reason I thought they were). See this huge weight cast in at the top of the flywheel? That is part of the weight system that balances the stock LT1 crank, pistons, etc. They are balanced to some type of spec, but it is not neutral.
He was going to use the the flywheel as a jig to bolt up the pressure plate....but with the flywheel not being neutral balanced that idea does not work.
He is going to see if he can locate a neutral balanced flywheel with a bolt pattern that will match to the LT4 pressure plate. Hope to have more information soon.
Chevycobb
01-31-2009, 02:30 PM
well I fired mine up today, using the locator pin as apoint for the dot, and didn't have any unusual vibrations. atleast none that were there before :shrug: but I think its gotta come back out now anyway because I think my clutch for is hitting the PP :mad:
good luck getting yours going again :thumb:
ACE1252
02-07-2009, 01:42 AM
Machine shop is taking forever....so I picked up my parts. Turns out they could not find a flywheel to use as a fixture in order to check the balance the Autozone pressure plate . They need a neutral balanced flywheel and the LT1 flywheel is not neutral balanced.
I've got a genuine Valeo clutch kit on the way.
This is what I'm going to do with the Autozone plate. My Dad does own his own machine shop(self employed). I'm going to take my oldest LT1 flywheel up to him and have him machine off the cast in weight on the back of the flywheel. This will allow me to get this flywheel neutrally balanced. Once that is done, they can check the balance quality of the Autozone pressure plate.
I'll post up what happens with my Valeo clutch install.
I honestly wonder if I'm a victim of SLP's good work. I say that because this LT4 plate I currently have is an LT4 plate with holes drilled around the perimeter of the clutch surface. Here is a picture of it.....
http://www.ace1252.com/images/SLP_clutch/SLPLT4_1.JPG
They neutral balanced the assembly by drilling material out of the plate at these 3 locations around the plate....
http://www.ace1252.com/images/SLP_clutch/SLPLT4_3.JPG
With that, I wonder if they balanced it much better than stock. I don't know. At this point, I think the LT4 Valeo knock offs at Autozone, Advance, etc are not balanced very well. I'll find out once I get my genuine Valeo LT4 kit.
FYI, I got the Valeo kit on ebay from here.....
http://cgi.ebay.com/ebaymotors/VALEO-CLUTCH-KIT-93-97-CAMARO-Z28-SS-TRANS-AM-WS6-LT1_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2 Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a1Q7c293Q3 a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem 350163384035QQitemZ350163384035QQptZMotorsQ5fCarQ5 fTruckQ5fPartsQ5fAccessories
$280 shipped with the "stock" GM disk is not a bad price for a genuine Valeo LT4 unit.
ACE1252
02-07-2009, 02:09 AM
Did you drive it or just rev it? You will not know until you feel it through the shifter around 2000-4000 on up. Just revving it, for me, didn't reveal any issues.....however it's a very different story when the input shaft is engaged under load.
I have read that flywheel/pressure plate balance issues show up in vibrations through the shifter.
Quote from this check sheet.....
"Notes: Clutch, Flywheel, and Trans Problems Tend to be Felt in the Shifter"
http://www.tracyvette.com/vibrationdiagnosis.html
Chevycobb
02-07-2009, 02:03 PM
just got back from driving it again and im noticing no vibrations up to about 5k rpms that didn't seem to be there before. just the typical vibrations you may feel from harder mounts.
ACE1252
02-13-2009, 04:25 PM
Ok gents, I've got an update.
My Valeo LT4 clutch kit arrived today. Here is the kit.....
http://www.ace1252.com/images/Valeo/Valeo_LT4_clutch_package.JPG
There is a difference between Valeo and the Duralast that is major(in my opinion).
Here is the Valeo LT4.....
http://www.ace1252.com/images/Valeo/Valeo_1.JPG
http://www.ace1252.com/images/Valeo/Valeo_2.JPG
http://www.ace1252.com/images/Valeo/Valeo_3.JPG
Here is the Duralast LT4....
http://www.ace1252.com/images/Duralast/Duralast_1.JPG
http://www.ace1252.com/images/Duralast/Duralast_2.JPG
http://www.ace1252.com/images/Duralast/Duralast_3.JPG
The drilled holes in edges of the pressure plate are where Valeo BALANCED the plate. The Duralast one does not have any weight drilled out of it. It appears that the Duralast one is not balanced. I have been through two new Duralast ones and both have bad vibrations above 4000rpms.
For reference again....my SLP plate has weight drilled out of it.....it is a Valeo LT4 plate.
I'll know for certain if the Valeo is right when I put this bad boy in tonight. I'll update then.
Chevycobb
02-13-2009, 04:28 PM
good to hear! hope the results are good!
Green96Z
02-13-2009, 06:58 PM
Good info, maybe you should post some of those pics in the sticky. Is it just me, or does the Duralast seem smaller than the Valeo? Could just be perspective.
ACE1252
02-13-2009, 09:18 PM
Both are the same size. Without any markings on the outer casing, it would be tough to tell them apart. But I think no holes drilled around the perimeter of the pressure plate is the smoking gun to the Duralast not being balanced.
I still plan on having this Duralast plate tested. I'm going to have my Dad machine off the cast in weight on one of my old LT1 flywheels. I will then have it zero balanced....then have that pressure plate checked. I'm curious on how out of balance it is.....
I've got my tranny back in my car....I still have to bolt up the driveshaft, torque arm, shifter, and a couple of other things.....so in a couple of hours I will be able to test out the Valeo plate.
ACE1252
02-14-2009, 12:35 AM
I just got back from my test drive and I am very happy to report that my car now revs to 6500 silky smooth.:cool:
The Valeo pressure plate fixed my problem. It's very clear now that the knock off plates sold at Advance, Auto Zone, etc are not balanced. All, beware of these plates.
Thumbs up to Valeo for putting out a quality product!!!:D
grimjeeper73
02-14-2009, 03:16 AM
you guys are making me dread this coming week of replacing my clutch lol
ACE1252
02-14-2009, 12:00 PM
LOL!:D
Pulling the tranny for me is now not an issue. I've had this thing out 4 or 5 times in the past 3 weeks. Once the car is in the air, I can have it out in 40 mins. working by myself.
The pointers I can give are this.....
Tranny jack is an absolute must....best $200 I spent.....unless you want to curse quite a bit. The pitch and angle changes that the jack allows for the tranny is a must.
When you secure the tranny to the jack, make sure it can't move(chain it securely to the jack)....if it does move, you will have a heck of a time getting it to line back up easily with the motor. You will know what I mean if the tranny moves on the jack after pulling it from the motor.
Use the actual tranny input shaft to properly align the clutch disk.
I had trouble with the disk either being too high, low, left, or right with the "plastic" input shaft. Use the plastic input shaft to get in the ballpark. Snug one bolt of the pressure plate to secure the disk. Remove the plastic alignment tool. Without the bell housing on, get the splines of the tranny input shaft into the disk. Loosen the snug bolt, now go the rest of the way in...the tranny will practically go all the way up to the pressure plate. Now snug that pressure plate bolt back down. Move the tranny back and forth to make sure there is no binding. Remove the tranny. Now you are done with aligning the disk and will have zero problems getting the tranny to go in....now tighten all the rest of the pressure plate bolts in a star pattern 1/2 turn at a time. Torque to 22 Lb/ft.
If the tranny does not go in there with zero pressure.....STOP. Something is either in a bind or not lined up right.
Stay away from the "cheap" LT4 plates, get a Valeo kit from the start. My lesson was hard learned, but I think it proves what I read about the non-Valeo plates.....they are not balanced.
Green96Z
02-14-2009, 10:12 PM
Definitely a must. But I just rented one for $15.
ACE1252
02-15-2009, 12:23 AM
That works too!:):)
