dugeman
01-21-2009, 07:39 AM
What parts are required to swap out the 6spd trans for a Th350. I have a fully worked Th350 with Trans brake I want to install in my 93 Z
Trans Swapdugeman 01-21-2009, 07:39 AM What parts are required to swap out the 6spd trans for a Th350. I have a fully worked Th350 with Trans brake I want to install in my 93 Z Stroked96Bowtie 01-21-2009, 12:55 PM What parts are required to swap out the 6spd trans for a Th350. I have a fully worked Th350 with Trans brake I want to install in my 93 Z Nice choice...I did a TH350 swap also but mine was an A4 from the factory. For my swap heres the laundry list: TH350 Trans and convertor (9in tailshaft if you want to use the stock DS) BMR LT1 TH350 crossmember New tranny mount (while its out mine as well replace it, not a solid one!) Lokar dipstick (believe 36in) TCI flexplate Shifter - I went with the B&M Rachet shifter and love it B&M Shifter cable kit There are some good write ups on LS1tech by Dlove on this...without that I wouldnt have been able to do myself. I was able to buy everything second hand except for the trans and convertor and cost me about $1300 with me doing all the work. Its not an easy job and takes some patience. As for yours being a 6speed car...theres more to yours but Im not familar with what else would be needed for your case. dugeman 01-21-2009, 08:44 PM Thanks for the info. | ||
