adjustable coil overs help with ride height? also what lb springs in rear for drag?
djm_e22
01-17-2009, 11:44 PM
Since I've installed the 9" rear end and did weight reduction in the ole LT1 camaro it now just rides too high. So if I get some QA1 adjustable coil overs I can lower the height of the car correct? Also I am going to first get the coil overs in the rear of the car first since it is extremely high in the back, what lb springs should I get for basically all drag racing, very little street?
speedracer2j
01-18-2009, 06:07 AM
Yes, coil overs will solve your ride height issue. Spohn is where I bought mine from, they, and everyone else has told me 150# rear springs for drag application.
Injuneer
01-18-2009, 06:31 PM
The quickest 4th Gen I ever had anything to do with (1.30 60-ft, low 8's at over 165 MPH) ran its best with my stock 94 Formula rear springs in it, and QA1 rear shocks. Car was a 97 SS convertible, but weight had been significantly reduced (3,500# with driver), so it was no heavier than a stock"ish" coupe.
