maverickmk
01-17-2009, 05:19 PM
There seems to be more blank space at the bottom of my signature than others have. I've tried to see if there were any returns at the end of my signature wording but the cursor stops at the end. Any suggestions or ideas?
Chevycobb
01-17-2009, 06:34 PM
I think it has to do with the avatar adjusting the size of your post block thing
edit: yeah, mine has a good bit under it
shock6906
01-17-2009, 06:55 PM
That's exactly what it is. If you make a longer post, then it increases the vertical height of your post window and the space below your sig shrinks.
6SpdLT1Z
01-17-2009, 07:44 PM
yup, so the solution would be to make long, drawn out posts. For example I could've just said yes but I'm rambling on to increase my post's length thus creating less gap at the bottom of my signature.
edit: huge gap at the bottom of my signature.
shock6906
01-17-2009, 07:55 PM
There are two reasons you still have a decent sized gap at the bottom of yours. One is that your signature doesn't take up much space in the first place, and the other is that your post wasn't long enough to extend the length needed to display your username, membership status, avatar, location, post count, fquick garage icon, and online status icon. I can almost guarantee if you make another post quoting both your first post and my post, you'll have a smaller gap at the bottom of your reply.
They should make me a moderator. :p
maverickmk
01-17-2009, 08:59 PM
excellent information :p
I hereby nominate shock for moderator of the month
