Wtb lt1 383!!!
LT1allday
01-15-2009, 02:27 AM
Does anyone Have a low milage 383 LT1 that they might like to get rid of? Thanks:)
LT1allday
01-15-2009, 06:45 PM
does anyone have one that may be interested in getting rid of?:rolleyes:
khojo16
01-16-2009, 12:10 AM
got a pretty good deal for you...i was building a second 383 LT1 for a daily driver, but just recently lost my job, and the engine is almost completely finished...heres what it is...
383 LT1, cast eagle crank, 5.7 eagle h-beam rods, keith black hypereutectic pistons (flat top, good for street use, and 11.0:1 compression), 643 stock casting heads slightly ported, comp pro mag 1.52 roller rockers, LT4 valve springs, new valve seals, 10* locks and retainers, hardened pushrods, LT1 red painted intake ported to match heads, heavy duty LT1 timing set, timing cover for 96-97 model with crank position sensor (you can swap it out if u need to), new windage tray, new melling oil pump...it was targeted to put out a little shy of 400rwhp, but not 100% sure on that...
here's the scoop, i originally bought the engine for a little over $4000, but ill sell it for $3195 because i need the money for school...lemme know what you think and you can PM me, reply to the thread, or email me at khojo16@comcast.net
RBE17
01-16-2009, 07:25 AM
I have a fresh 383 built for boost. PM for the details if you're interested.
khojo16
01-16-2009, 10:10 AM
o and forgot to mention cam specs on mine...
its a custom grind cam with 230/236 duration and .516/.527 lift with the 1.52rr's and 110 LSA
khojo16
01-21-2009, 11:41 AM
hey any word on if you got an engine yet? or are you still looking?
