Ekof96Z28
01-04-2009, 03:19 PM
Hey guys. I'm just gathering parts to put everything together. I have the engine completed and waiting to go in.
What do you guys expect from this combination.
Eagle street/strip rotating assembly .020 over stock stroke
comp cams 233/239 112+3 LSA .569/.577 lift w/ 1.6s
Pro mag 1.6s SA
Crane springs(dont remember part ## offhand)
Hardened pushrods
Cloyes Timing set
Heads milled .005 to true the plane
3 angle valve job and light porting w/ port matched intake
K&N Cold air/1LE elbow
Hooker LTs w/ 2.5" true duals dumped at axle
MSD Coil
Racetronix 42 lb injectors
Racetronix fuel setup w/ walbro 255lph
Taylor OVC Wires
Either Stock or Accel opti.
What about the MSD cap and rotor? Are they worth it?
Going to go with one of Ions tunes until I can afford a dyno tune
I think thats about everything. I may have forgotton something.
Do you guys think I can avoid upgrading the fuel pump for now?
What about the stock throttle body? Will I be losing power with it?
Let me know what you think about it.
It will be through an A4 with a 3200+ stall and 3.23 10 bolt.
Pro mag 1.6s SA
Hardened pushrods
Cloyes Timing set
MSD Coil
Taylor OVC Wires
