94camaroracer
12-25-2008, 11:13 PM
I bought a 94 camaro with a 3.4 v6. the owner told me it had blown head gasket and it was setting up for 6 months. I had the car towed to a local mechanic to check it out for me due to had just gotten out of the hospital. He ran a compression test and pressure test on the cooling system, everything came back fine. He did find out the the chain was knocking, so i had a new timing chain and gear set put on and in the prosesse the old water pump was gumed up with red antifreeze and as a precaution flushed the whole system. So so far it has a new water pump, timing chain set, and spark plugs. He put " liquid glass " in it just to be safe. Drove it home [ 2.3 miles ] with heat on and it was just cold air, car did get up to operating temp. Then the next morning drove it to my uncles house [12 miles ]and it started to over heat, about a quarter mile or less from his drive way the car was reading 260 on the temp gauge. So i replaced the thermostat, during replacing the thermostat i cleaned out chunks of crystallized liquid glass from were the thermostat sets in the intake manifold. So far we have the following 1. new timeing chain set 2. new water pump 3. new thermostat. Started the car up , as the temp came up to operating temp it slowy started to clime even higher to 260 setting still. while letting the car cool off we noticed that all the hoses are a little warn but not hot even know the car was just a 260 and the system does build prussuer. we let the car cool off and took off the radiator cap [ wich is new ] and the water is circulation but i am not losing any water. why or better yet how is it overheating setting still? the hoses are warm but the block is hot. can any one help me?
