Power window seems to be binding up
wrd1972
12-08-2008, 04:39 PM
When raising the right side power window on my Camaro, it will stop in random places like something is binding. I have done the thermal breaker bypass and I have done the relay mod so power is not the problem.
I recently lubed the tracks and inspected things and everything looks good. Seems to come and go.
If you lift the window by hand while raising it, I can not feel any binding. Really pissing me off.
Could this be the motor going bad?
Counted Out
12-08-2008, 08:06 PM
That's what happened when my motor went bad.
dan_white798
12-08-2008, 08:17 PM
im having this same problem with my driver side window. i was planning on just replacing the motor. have you or anyone replaced one yet? if so could you tell me where to get some instructions and where to buy the motor? thanks
shoebox
12-08-2008, 10:52 PM
http://shbox.com/page/windowmotor.html
wrd1972
12-08-2008, 10:59 PM
This motor was been replaced by the dealer back in the warranty days. I have the access holes already drilled in order to remove it which is a piece of cake. Guess i will go ahead and get a new one.
Green96Z
12-09-2008, 12:31 AM
Mine used to rattle like crazy and get stuck sometimes, turned out most of the teeth were rounded off on the regulator. If you change out the motor and it doesn't fix it you could always take it back (I did that once :D).
cool_breeze
12-09-2008, 08:36 AM
Mine did the same thing when the motor was going out, if you already have those holes drilled then it's pretty easy, I used a piece of 2x4 wood to brace the window up while I removed and replaced the motor.
