What size Belt when deleting Smog Pump on 91 TPI?
Old Jan 5, 2003 | 08:16 AM
Mr. T's Z's Avatar
What size belt do I need when deleting the smog pump on my 91 B4C with a 350 TPI?
Thanks,
Tyler
Old Jan 5, 2003 | 08:27 AM
aklim's Avatar
You need to see how much extra you have then try a few sizes smaller. That is what I did. Buy a few belts and return the rest.
Old Jan 5, 2003 | 09:06 AM
Mr. T's Z's Avatar
Any Belt numbers?????????????
Old Jan 5, 2003 | 09:36 AM
DABE92's Avatar
http://www.thirdgen.org/newdesign/tech/serpentine.shtml
tell ya how to do it....
"You will however need a longer belt, I used Dayco 968K6 belt. It is basically a 96.8" 6 rib belt. All parts stores stock just about every length of belt in every width. They should be able to find it using these numbers. If you have an underdrive pully you will need Dayco pn# 935K6 which is actually shorter than the stock belt by one inch."
Old Jan 5, 2003 | 09:39 AM
DABE92's Avatar
ohh....your gonna have to shell out a good 30 bucks for it also
Old Jan 5, 2003 | 10:09 AM
Mr. T's Z's Avatar
Thanks guys!!!!!
Old Jan 5, 2003 | 12:54 PM
mjcent922's Avatar
Just cut your belt and route it around and see how much left over you have.Use that as a measuring devise for the shorter belt
Old Jan 5, 2003 | 02:27 PM
kandied91z's Avatar
why not use the delete pulley........cheaper and you don't have to worry about a new belt.
Old Jan 5, 2003 | 07:04 PM
bigmike92z's Avatar
for about the same price you can get a shorter belt and have less crap under the hood.
Old Jan 5, 2003 | 07:20 PM
DABE92's Avatar
exactly...clean it all up...
also saves weight...
Old Jan 5, 2003 | 08:52 PM
91 Redd Sledd's Avatar
When we deleted the smog pump on my 91 I used the same belt as before but I think we routed it a little different.I also have underdrives (3 piece) so the belt was already shorter anyway. I don't have acces to my car to tell you how it was routed but if ya can't figure it out I can call my friend that is storing the car for me and have him let me know how it is routed.
James
Old Jan 5, 2003 | 08:56 PM
DABE92's Avatar
ill take some pics soon of how i have mine routed...
Old Jan 5, 2003 | 11:23 PM
kandied91z's Avatar
well you guys should certainly do what you think is best. i just wanted to let others know who might not want to hassle with changing there belt that the option is out there.
i have so many aftermarket part numbers and special pieces that i must remember in case of an emergency that a different belt and part number is one last thing i want to worry about being in stock at a store if i don't have to.
it's cheaper, weighs less than a paper weight and it's out of the way so no one will see it anyway.
do what you like, but it's nice to have options....
Old Jan 6, 2003 | 02:08 PM
bigmike92z's Avatar
cheaper?.. if i remember correctly yours ended up costing you 32 dollars. i paid 20 dollars for my stock serpentine belt.
HectorM52
Jul 30, 2017 11:46 AM
alphaauto
Jan 23, 2015 07:42 AM
Jason Short
Jan 19, 2015 06:34 PM
Timberwolf
Aug 9, 2002 11:24 AM
