SS44Camaro
12-06-2008, 04:41 AM
i need a bracket for my lt1 pcm (94 z). is the bracket for the ls1 the same? it is the same on caprice and roadmasters even with the L99 right?
thanks guys
thanks guys
lt1 and ls1 pcm bracket same?SS44Camaro 12-06-2008, 04:41 AM i need a bracket for my lt1 pcm (94 z). is the bracket for the ls1 the same? it is the same on caprice and roadmasters even with the L99 right? thanks guys SS44Camaro 12-06-2008, 03:44 PM maybe i should have posted this somewehere else??? Injuneer 12-07-2008, 11:41 AM Its in the right forum. Its just possible that no one here has ever had a reason to compare the PCM mounting brackets on the LT1 vs. the LS1 vs. the B-Bodys. The LS1 PCM's are completely different than the LT1's, with regards to dimensions, and the mounting location is completely different, so I suspect the brackets are different, but that's just a guess. Probably have to get someone to post a picture of the LS1 PCM with mount, so that you can compare it to your LT1. Maybe put a post in the LS1 Engine Tech forum asking if anyone can post a picture. SS44Camaro 12-07-2008, 03:02 PM ok if the dimensions are different the brackets are probably different too... i figured they would be, but ive never payed attention under an ls1 car to remember. they will probably be the same in the b body cars with the lt1 and l99 though you think? thanks fred | ||
