Rear end question
Old Dec 4, 2008 | 05:21 PM
Godly96_SS_Here's Avatar
Rear end question
I have a 93 T/A and the rear end does no more smokey burnouts.
Anyway, its only 1 tire fire for me! I have been looking at getting this fixed, but I am unsure is exactly what I need? I found a guy here that is selling a Auburn Posi for a 7.5 10 bolt series 2...Will this work for me? and I would also like to go with 3.73's while I'm there. Also found this on eBay? But I know I don't want a locker.
http://cgi.ebay.com/ebaymotors/Parts...1%7C240%3A1318
Old Dec 5, 2008 | 09:20 AM
seawolf06's Avatar
You have an auto, so the 2 series should work for you. I'm not sure if there are different 10 bolts for chevy, though. You definitely do not want a locker.
If you get 3.73's, make sure you get some that fit the 2 series carrier.
Old Dec 5, 2008 | 10:38 AM
camarobird92's Avatar
Or also that 3 series carrier would work with gears included. To run 3.73's on a 2 series carrier, you need either a special ring gear or a spacer for the ring.
Old Dec 5, 2008 | 11:00 AM
97FormulaWS-6's Avatar
Try just changing the fluid first... remember to add real GM Posi additive (available at any GM dealership). Sometimes that's all it takes to get the posi working properly.
Old Dec 5, 2008 | 03:29 PM
I have already changed the fluid and I used the additive also, it didn't work for me.
Old Dec 5, 2008 | 03:32 PM
I was looking, and I think I have a 3 series carrier? I have 3.23 gears so it's possible the 3 series should be fine?
Old Dec 5, 2008 | 03:34 PM
seawolf06's Avatar
I forgot the Autos had that option. Yeah, that should be the 3 series carrier then, sorry.
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
