shop full of 93-02 f-body parts FS in DFW
STS95T/A
11-27-2008, 01:37 PM
Here is a list of everything I can think of, if you need anything else for a 93-02 camaro firebird or trans am feel free to shoot me a pm. pics of my shop are at the bottom of the page
93-95 V6 Single fan assembly-$40
93-97 v6 manual radiator-$40
93-97 v8 manual radiator-$70
LT1 dual fan assembly-$80
98-02 v6 manual radiator -$40
Salad shooter center caps -$5 each
93-97 headlight control module-$20
LT1 PCM bracket-$10
93-97 fuse and relay cover (under hood)-$10
93 seat belt guides in gray-$10 pair
93-96 camaro HVAC controls-$15
93-95 dual horn assembly-$15 pair
Triangular mirror bolt covers-$5 each
Lt1 rear view mirror-$20
B-pillars in gray-$5 each
Hatch release button-$5
cig lighter in black-$3
93-96 camaro shift knob-$5
93-96 camaro automatic shift plate-$20
93-96 Camaro V6 115 mph gauge cluster 125k miles-$20
94-96 Camaro 306k , 150k and 174k miles-$30 each
98-02 Camaro 3 channel ABS control module -$20
93-96 Camaro drivers side air bag-$40
93-97 Camaro/Firebird passenger side airbag-$30
93-97 Camaro Complete steering column minus air bag and steering wheel-$60
93-96 Camaro dash (not upper dash pad)-$60
323 LT1 rear end complete minus calipers and rotors (3 channel)-$200
342 LT1 4 channel rear end complete minus calipers and rotors-$250
LT1 power steering pump-$25
LT1 power steering fluid reservoir-$15
Lt1 Camaro complete headlight bar-$80
93-97 steering rack-$30
Stock 94 LT1 fuel injectors (set of 8)-$30
Washer fluid reservoir-$10
Complete LT1 t-top conversion includes: t-top , center divider on roof , wether stripping , aand b pillars, t-top brackets-$280
93-97 Camaro window lock and mirror controls-$30 pair
93-96 Camaro CD player-$50
93 – 97 Firebird CD player -$50
T-top sunshades in tan-$25 pair
t-top holders ( mounted in trunk)-$25 pair
94-97 fuel rails-$30
Lt1 starter-$40
Complete 3.8 L t5 conversion: tranny , hydraulics , clutch basket, pedals and cross member-$300
lt1 smog pump-$10
lt1 timing chain-$10
93-94 timing cover-$30
95 lt1 timing cover-$40
Lt1 tensioner pulley assembly-$20
Lt1 crank pulley-$15
Oil dipstick w/ tube and stick-$15
Lt1 water pump drive-$20
Lt1 water pump drive coupler-$10
Lt1 complete front spindle assembly-$40 each
Lt1 oil pump -$20
Lt1 oil pump drive-$20
94 lt1 opti -$40
Lt1 cam timing gear-$10
Lt1 3-channel stock axel-$30
Stock rear lca’s-$20 pair
Stock lower front a-arms-$15 each
93-97 stock v6 2-pice drive shaft-$40
Stock torque arms-$25 each
98-02 passenger side air bag-$30
Lt1 ICM /coil assembly-$25
Lt1 valve covers -$25 pair
93-02 camaro tail light center panels in maroon, green, white, and red-$40 each
LT1 flex plate-$20
96-97 airbag control module-$20
93-95 airbag sensor set (3)-$20
97 lt1 m6 motor harness-$40
93-95 Firebird Dash (not upper dash pad)-$80
93-96 camaro dash (not upper dash pad)-$60
Complete 93 lt1 intake manifold with throttle body and fuel rails-$120
Red firebird low-rise hatch-$50
Red, black, green, and white camaro z28 hatch-$40
Stock LT1 lifters (16)-$25
Stock LT1 rockers-$20
Stock LT1 push rods (16)-$10
93-02 F-body hidden hitch-$40
LT1 accessory bracket-$30
95-97 heater hoses-$25
Camaro taillight harness-$20
96-97 V6 MAF sensor/ throttle body-$20
LT1 emergency brake cables-$30 set (3)
LT1 k-member-$40
F-body spare jack assembly with wrench-$25
A-4 pedal assembly and sensors-$30
LT1 brake master cylinder-$10
LT1 brake booster-$10
A-4 shifter with all cables-$40
LT1 AC condenser-$25
LT1 stock throttle body-$25
LT1 gas tank straps-$20pair
Ls1 lifters-$40
96/97 LT1 exhaust manifolds-$30
Firebird window, mirror and lock controls (both sides)-$40
Camaro side mirrors in green-$20 each
Lt1 MAF sensor-$30
Firebird door panels in black leather-$50 pair
Lt1 t56 bellhousing-$100
10 bolt stock dif cover-$10
K&N cold air intake tube (w/o air filter)-$40
Lt1 water pump-$40
94 lt1 a4 pcm-$50
93-97 intake manifold-$40
Firebird rear bumper in silver or teal-$40 pick up only
93-97 firebird passenger headlight assembly in teal or white-$80 each
93-97 firebird drivers headlight in teal , silver or white-$80 each
98-02 power steering rack-$40
98-02 steering coupler-$20
Ls1 front breaks (conversion for lt1)-$200
98 ls1 heads-$75
373 gear set-$70
95 lt1 /m6 pcm-$50
Lt1 throttle position sensor-$10
Lt1 MAP sensor-$10
Lt1 clutch fluid reservoir-$10
Lt1 braided clutch fluid line-$20
Ls1 starter-$40
Lt1 oil pan-$20
93-02 coolent reservoir with good battery tray-$30
Lt1 plastic fuel lines-$20
Ls1 K&N air filter-$15
Lt1 K&N air filter-$15
All prices are obo and without shipping
i'm located in mansfield tx 76063
My paypal/e-mail is f-bodyparts@hotmail.com
Robbie
http://i273.photobucket.com/albums/jj237/STS95TA/102_3022.jpg
http://i273.photobucket.com/albums/jj237/STS95TA/102_3021.jpg
http://i273.photobucket.com/albums/jj237/STS95TA/102_3020.jpg
http://i273.photobucket.com/albums/jj237/STS95TA/102_3019.jpg
http://i273.photobucket.com/albums/jj237/STS95TA/102_3018.jpg
http://i273.photobucket.com/albums/jj237/STS95TA/102_3017.jpg
http://i273.photobucket.com/albums/jj237/STS95TA/102_3016.jpg
http://i273.photobucket.com/albums/jj237/STS95TA/102_3015.jpg
http://i273.photobucket.com/albums/jj237/STS95TA/102_3014.jpg
http://i273.photobucket.com/albums/jj237/STS95TA/102_3013.jpg
STS95T/A
11-28-2008, 09:44 AM
to the top
STS95T/A
12-01-2008, 11:46 AM
to the top
RobZ
12-02-2008, 06:10 PM
How much for a 93+ rear prefer 98+?
STS95T/A
12-03-2008, 01:14 PM
pm sent
thanks
robbie
Jlo
12-04-2008, 04:26 PM
Would you do $50+ship in the LT1 fans??
slingshot
12-04-2008, 05:07 PM
Could you pm me if you have the backing plates for the 3 channel rear end?
texas94z
12-04-2008, 05:12 PM
Pics of the 373s?? 2 or 3 series carrier??
STS95T/A
12-04-2008, 08:02 PM
pm sent
sorry but no 3 channel backing plates
thanks
robbie
Pony Punisher II
12-06-2008, 07:30 PM
pm sent
thanks
robbie
Hey I have a ton of 3 and 4 channel backing plates. :)
40 bucks for the 3-ch
Robbie, I need a T56 - good or broken. Gimme a call 817-300-6840
-Jason
STS95T/A
12-07-2008, 09:01 AM
sorry but i have to take apart a good rear to part with the backing plates. i only sell them if i come across a rear that is junk
i might have a t-56 for you here tomorrow, i will let you know
thanks
robbie
