Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
ONE BADDDD 1994 Camaro Z28 FOR SALE -383 supercharged
Old Nov 26, 2008 | 06:16 AM
detroit1994z28's Avatar
For sale --one bad 1994 camaro z28 -383 stroker with all the best parts -Supercharged. Low miles on the body 35,000 I beleive. This car is very fast. It will actaully pin you in the seat from a 40mph roll in 3rd gear while smoking the tires. He's looking to get 15,000 OBO (313)790-0633 - Mario
383 Stroker Built by Motorcity motorsports
All blue printed and balanced professionally bulit with all documentation
AFR heads 210 s full race port and polish
Crane gold roller rockers
4 bolt splayed mains
Eagle crank double keywayed ,knife edged ,fully polished
Eagle H beam rods
J & E pistons dish with ring lands moved for blower application
Comp cam Custom grind have card
H D high volume oil pump
Clevit bearings
Canton oil pan 7.5 quart
A T I Liquid balancer
Tren harden pushrods
Engine was tuned by Troy Brown from Hard core motorsports
EXHAUST
Custom made headers 1 7/8 primary into 3.5 "collectors
Has true duel exhaust collectors back H pipe into single chamber flowmasters dump off at axle
TRANS built by Joels on joy
400 turbo
H D housing
34 sprag
reverse manual valve body
trans brake
B&M shifter pro stick
3000 stall 3500 flash stall by red neck performance
custom drive shaft
BMR conversion kit for install of 400 turbo trans
Also still working speedo he did some kind of conversion to keep it working
AIR INDUCTION
Vortech S trim 10lbs boost
Vortech aftercooler water to air
BBK throttle body
Stock intake fully port matched
FUEL SYSTEM
Fuel tank sump ed
Aeromotive a1000 pump
All stainless braided fuel lines front 2 back
All A N fittings
In line micro filters
Pressure regulator
Custom fuel rails made by CPR
60lb fuel injectors Simmens
IGNITION
MSD 6a
MSD boost controller
MSD wirers
MSD coil
SUSPENSION & WHEELS
Weld EVO 18" axis 2 chrome . 5 year warranty on chrome lifetime on wheels
Front toyo proxes 275/35zr18
Rear BFGs drag radials 315/30r18
BMR panhard rod
BMR lowering springs
BMR torque arm
BMR control arms
GAGES AUTO METER
Cobalt oil pressure
Cobalt boost
Cobalt air/fuel
Cobalt water temp
White pantham fuel pressure under cowl
BODY
Never been painted original all ways garage kept
Cowl hood fiberglass
Bullet grill
Chrome Z28 & camaro emblems
Roll / light bar
OTHER ACC
Viper alarm with auto start
Bel wide band 615 str radar system
REAR END
10 bolt 3:42 gear
[IMG]
Collector Car
Dec 17, 2014 01:12 PM
NED4SPD
Sep 16, 2002 10:45 PM
dreamer1q
Jul 24, 2002 04:39 PM
dreamer1q
Jul 9, 2002 05:37 PM
dreamer1q
Jul 8, 2002 08:47 PM
