C6 Z06 18x9.5 wheel on all 4 corners on 4th Gen
A35TH-SS
11-25-2008, 08:06 AM
Correct me if I'm wrong but I believe a stock Corvette C6 Z06 18x9.5 will fit all 4 corners of my 02 Camaro Vert without any spacers but which tire size should I go with? I want to stay as close to the stock height of 25.7". I'm looking at the stock Z06 tire 275/35/18 but don't know if it will clear the stock suspension. SLP sells a set which are very close to the Z06 wheel. Anyone here have the SLP wheels?
http://www.dupreelakes.org/images/slp-wheel.jpg
Thanks,
A35TH-SS
Injuneer
11-25-2008, 11:52 PM
I've seen several references that list the stock C6 Z06 wheels as 18x9.5" +50mm offset. If that's the case, should not be any problem running them on all 4 corners. Since the 275/35-18 tire has a diameter that is about 1/10th inch less than the stock 275/40-17 tires that were used on the WS6 and SS coupes, there should not be any concern about the tires interfering with the suspension.
I have found one reference on a Corvette website that lists the offset as 40mm, and that would move the tire another 0.4" toward the outside of the fender, possibly causing the outer edge of the front tire tread to rub on the plastic inner fender liner when the wheels are turned toward full lock. But most reference seem to indicate the offset is 50mm. If you are looking at "repro" wheels, ask the manufacturer what the offset is. They do not always match the factory specs.
A35TH-SS
11-26-2008, 05:00 AM
I found the rims at SLP 18x9.5 front and 18x11 rear. They are described as "Tired of chrome or silver wheels? SLP has the answer with these OEM style quality wheels featuring a metallic, gunmetal finish and a machine spoke face. Treat your 1998-2002 F-Body with a new modern look at the fraction of the cost of traditional aftermarket wheels. Sold as a set of four with plain center caps."
Note: Optional logos can be purchased from authorized GM licensed distributors.
Link Below
http://www.slponline.com/view_product.asp?P=81031&BIG=81031-1
Injuneer
11-26-2008, 05:26 AM
"OEM style" identifies them as an aftermarket wheel, not a factory or OEM wheel. In that case, you should ask SLP to confirm the offset.
A35TH-SS
11-26-2008, 07:58 AM
I called and the rear wheels are for Corvette not Camaro. They said the 18x9.5 will fit the camaro with 275/35/18 tire. Are these any different than the other aftermarket wheels I wonder?
But I am also looking at the New ZR1 Wheel in a Chrome finish 18x9.5 56mm offset. This should fit front and rear on the 02 SS.
http://www.westcoastcorvette.com/p-2129-2009-zr1-reproduction-wheels-chrome.aspx
http://reviews.carreview.com/files/2008/08/2009_chevrolet_corvette_zr1_wheel.jpg
rbaksi
11-27-2008, 03:09 AM
I wanna see how those C6 ZR1 wheels look on a car.
A35TH-SS
12-01-2008, 09:17 AM
I went ahead and ordered new tires and wheels. The tires are Goodyear Eagle F1 Asymmetric 275/35/18 and the wheels are the 2009 ZR1 18x9.5 chrome with 56mm offset. The wheels are new reproduction and will be shipped around end of December. I will post pics when they are installed.
hey01
12-11-2008, 10:13 AM
they'll also be heavier then a ton of bricks.
A35TH-SS
01-22-2009, 06:29 AM
I just finished installing the ZR1 wheels on my 02 35th LE. It was night when they were installed but I will have daytime pics coming.
http://www.dupreelakes.org/images/camaro-zr1-wheels-pic2.jpg
http://www.dupreelakes.org/images/camaro-zr1-wheels-pic1.jpg
MILESF
01-23-2009, 10:34 AM
Are those 18" X 91/2"? I have a set coming from California. Same size. AWESOME!!!
Now you need to drop it a few inches!!!
A35TH-SS
01-24-2009, 11:57 AM
The wheels were made in China. I don't know how many companies are making these replica wheels or importing them. I purchased these from WestCoast Corvette. They are 18x9.5 56mm offset with 275/35/18 tires.
Here are the pics. Before and after.
http://www.dupreelakes.org/images/camaro-zr1-wheels-pic5.jpg
http://www.dupreelakes.org/images/camaro-zr1-wheels-pic4.jpg
http://www.dupreelakes.org/images/camaro-zr1-wheels-pic3.jpg
http://www.dupreelakes.org/images/camaro-zr1-wheels-pic6.jpg
IXLR894Z28
01-24-2009, 09:50 PM
Those are great looking wheels, hopefully they aren't too much of a PITA to clean.
Ten_32
01-27-2009, 12:53 AM
I'd love to see how those look on a Bird. Very nice on that SS!!
6SpdLT1Z
01-27-2009, 09:54 AM
I think those ZR1 wheels would look pretty damn good on a LS2 GTO.
SOLO Z
02-05-2009, 01:06 AM
those new ZR1's is Th33 SeX!!
Z28avalanche
02-19-2009, 01:30 PM
I run 275/35/18 Z06 rapped in BFG KDW 2 on all four corners with no issues.
