ghost stripes
11-17-2008, 06:07 PM
thinking of switching these
will a set of 315 40 17s from my 95 trans am fit my 1990 camaro rs?ghost stripes 11-17-2008, 06:07 PM thinking of switching these Injuneer 11-19-2008, 12:01 AM Are the tires 315/40-17 or 315/35-17? Typical aftermarket tire on the 4th Gens is a 315/35. I'm not aware of any street tires in 315/40. Are they a competition tire? In any case, I doubt that there were any stock wheels on a 3rd Gen Camaro that were wider than 8". You can't put a 315 tire on an 8" wide wheel. Typically you need at least a 10" wide wheel for a 315/35-17. lt1 beast 11-22-2008, 01:03 AM I think he meant will the wheels and tires fit ( same bolt pattern, wheel to fender clearances) that sort of thing. Not trying to discredit your post. However it is 1 am so i may be mistaken. camarobird92 11-22-2008, 12:43 PM If you are talking about swapping wheels and everything. You can if you get spacers for your third gen. 3rd and $th gen use a much different backspacing. kandied91z 12-03-2008, 12:05 AM direct answer is no. | ||
