1999 TA posi Track Question
Oli_Man
01-03-2003, 04:09 PM
I bought a rearend out of a 1999 Trans AM so I could have posi track on my firebird, but when I took it to my mechanic he told me that it diden't have posi track because whrn you turn one side the other side turned the opposite way.
but when you turn the yoke both sides turn the same way.
But, when you grab ahold of one side while you turn the yoke the side you grab would hardly give any resistance and the other side keeps turning the same way freely.
I would just like to know if I got ripped off on this rearend or not. upon opening the cover on the rearend there is a posi track box inside there.
any help on this topic would be greatly appreciated, this is my first dealing with a positrack unit.
also it is going on my 1999 firebird, I figure it should bolt right up. but if anyone knows of a problem with this feel free to chime in.
jd13
01-03-2003, 04:41 PM
If you bought the stock rearend out of the Trans Am, then I'm 99% sure it has posi. I don't know much about rearends, but I think your mechanic may be mistaken.
PhantomTA
01-03-2003, 04:49 PM
they are limited slip.. not really a true posi... works just the same
Oli_Man
01-03-2003, 06:08 PM
what is the difference between limited slip and posi?
mark896
01-03-2003, 06:25 PM
In my opinion, the limited slip differential is better. Especially for my daily driver. Posi's always spin both tires no matter what so sometimes they are harder to control. On a limited slip differential like yours, one wheel can slip and the other can still retain traction. You didn't get ripped off.
My ambitionz
01-03-2003, 06:37 PM
they are both the same! posi is GM's name for a limited slip diff.
other names for limited slip is sure-grip (chrysler), equal lock, those are the most common, But i've heard people say other names. man an easy way to find out pull the cover off and look for a set of disks,(clutch pack) they are behind both side gears. looks like a whole bunch of disks all packed together.
remember just because it's limited slip dosen't mean your wheels will turn together all the time, those friction disks are made to "slip" also to allow one wheel to spin faster than the other, during cornering or what not. They have a spring tension to keep the clucthes engaged and both wheels spinning. the only time you can be 100% sure that both wheels are going is under high torque situations. do a burn out and look for two tire patch marks;)
then you'll know :p
btw when u say u grab a hold of one wheel and put resistance to it, and the other wheel just spins freely, that is lsd. the wheel with the most traction (one you are putting resistance on) is gonna receive most of the torque , while the other one will just at a slower rate.
chevy qc
01-04-2003, 02:54 AM
the reason it turns the opposite way is because it's not a clutch type limited slip. only the clutch type's or true lockers hold still. the torsen works alot like a gov-lock which will also turn like an open diff until torque is applied. if you pull the cover off, you'll find a torsen in there which will work the same pretty much as the auburn does in the older models.
stik6shift98
01-04-2003, 03:22 AM
ya u didnt get ripped off so its all good......:D :D
My ambitionz
01-04-2003, 01:33 PM
:confused: :confused: how come when i pulled my cover off i saw a clutch pack??:confused: :confused:
Freak
01-04-2003, 09:42 PM
because you have a 98. they switched to torsens as standard in 99. in 98 all Z's and standard T/A's and Formulas came with an auburn clutch type.
L8ER
12-02-2004, 09:25 PM
From what i have read and seen it is called a open end posi, it will grab when you are stright but when you turn it will give on one of the wheels so it can turn better..Mine does the same thing I noticed it when I helped a friend put in a locker. When I hit the gas I will lay two solid black marks :D
robvas
12-02-2004, 10:10 PM
It might be worn out. My buddies 99 or 00 TA has like 50,000 miles on it, and when he power brakes it, most of the time only one tire spins :(
Buy a new limited slip for it if you want to be 100% sure.
mullettour
12-02-2004, 10:45 PM
The torsen is a gear type torque sensing limited slip differential. It senses the torque difference applied to each drive axle. It has to be a significant difference. This differs from standard limited slip differentials in that they are a preloaded clutch type. They have different springs that increase the preload on the clutches. That is why your limited slip seems broken.
Mr_Bond
12-03-2004, 12:11 AM
Here a pic of both types:
Zexel Torsion (http://www.stang.cc/tmcaalbums/Bond/10302004_002.jpg)
Auburn Type (http://www.stang.cc/tmcaalbums/Bond/10302004_003.jpg)
87DJP2001
12-03-2004, 05:08 PM
No mater what they name them, they are all "LIMITED SLIP".
