SteveSS
11-07-2008, 06:25 PM
A roughneck worte GEOLOGIST on the outside of the back window of my 2007 Hummer H3. I washed it off but it is visible whenever the window is wet or dusty again.
Any ideas? I tried scrubbing with soap and water and the foaming glass cleaner. No Luck.
OneBadRedz28
11-07-2008, 07:02 PM
damn bro that sucks i work at a dust hole and we've wrote on the windows and never anything like that. Only thing i can think of is your glass ass some kinda protective coating on the exterior that got scratched.
Chrisz24
11-13-2008, 11:45 AM
I often use polish on the glass, it should do the job.
shock6906
11-13-2008, 02:12 PM
How about steel wool?
I've got a feeling that if dust left permanent (or semi-permanent) scratches on his window that even 0000 steel wool would do the same or worse.
lt1 beast
12-19-2008, 09:37 PM
no steel wool will not scratch windows. I detail and paint cars all day and use it on every car. never scratched one. It may be grease from a sweaty finger try using some simple green or alcohol. or wet the window and use ultra fine steel wool or a brand new razor blade. **If u use a razor blade 1) dont cut yourself ;wear gloves, 2) and use an angle of about 20 degrees or so to prvent the razor from catching the glass. I have had my wipers come off scratch my glass and all i did was use fine steel wool and compound. youd never know it was there. so if all else fails try compounding the window
with a polisher or orbital buffer, either should be sufficient.
slomarao
12-19-2008, 11:56 PM
the zaino glass polish will get it off. no prob
Pandamonkey
01-04-2009, 12:48 PM
Turpentine and a copper brush!
MasterZ28
02-12-2009, 12:36 PM
+10
This took off paint over spray and embedded dust on my second pair of T-Tops without scratching anything. I totally agree.
Venomous360
03-03-2009, 11:18 PM
Really?? I have this problem as well, It really works? What kind of compound, just polishing compound?
