Clutch or motor mount or what?
billscamaro
10-30-2008, 05:26 PM
6 months ago i replaced my clutch and when finished, my car has had a bad vibration that shakes the entire car. It only happens when the clutch is engaged from a dead stop and when engaging it when downshifting. And when the engine is under load and i press the clutch quickly, i hear a single knock.
Someone advised me that maybe my drive shaft needs to be checked or most likely the yoke or universal joint needs to be replaced on it. I replaced the rear end with a moser 12 bolt recently and the problem still exists.
The vibration goes away if i rev the motor to 2k rpms when i release the clutch. If i do not rev it up a small bit, the car violently vibrates and you can hear a ticking sound underneath the car. (can't really tell exactly where) I have never experienced this at all until i replaced my clutch and perhaps i screwed something up during the install.
As always, i appreciate everyones input and thanks in advnace.
billscamaro
10-31-2008, 05:33 AM
anyone have any idea?
AL SS590 M6
10-31-2008, 07:25 AM
Sounds like clutch shudder to me. What pieces did you use, clutch, pressure plate, flywheel?
billscamaro
11-02-2008, 12:47 AM
not sure, i bought the car with what it has in it, the transmission was shot when i bought it so i put a new one in it and used the textrailia clutch that was in it
so when i get a new clutch the problem will be resolved?
thinkin about gettin the LS7 clutch kit
