krillformula
10-12-2008, 04:11 PM
I havent followed the development that much of the new camaro, but what kind of rear will be in it?
Rearend?krillformula 10-12-2008, 04:11 PM I havent followed the development that much of the new camaro, but what kind of rear will be in it? JasonD 10-12-2008, 04:36 PM 4.5 link independant http://www.camaroz28.com/gallery/main.php?g2_itemId=936 MetalDragon 10-12-2008, 05:44 PM Have we heard anything on gearing? Jason Dove 10-13-2008, 02:44 AM 3.27 for everything but the manual SS which will be 3.45 in the rear end. If you go to chevy.com/camaro there's a specifications PDF if you want to see each of the ratios for the transmissions. krillformula 10-13-2008, 09:58 AM Ok thanks! 10Redrocket 10-20-2008, 11:21 PM I ordered an SS today with an auto trans and the paperwork lists the axle ratio as 3.45, so I'm assuming that all the SS's have the same ratio. MetalDragon 10-21-2008, 12:46 AM I haven't seen anything to indicate different. Jason Dove 10-24-2008, 08:20 PM http://www.chevrolet.com/camaro/pdf/2010+Camaro+Specifications.pdf The spec says on page 3: Hydramatic 6L80E speed automatic(SS) w/Tapshift .... Final Drive Ratio: 3.27 mdenz3 10-28-2008, 01:33 PM Does anyone know the ring gear diameter on these? 10Redrocket 10-28-2008, 10:18 PM http://www.chevrolet.com/camaro/pdf/2010+Camaro+Specifications.pdf The spec says on page 3: Hydramatic 6L80E speed automatic(SS) w/Tapshift .... Final Drive Ratio: 3.27 Correct! My fault, I was looking at standard equipment on my paperwork. In the options section under the auto trans it lists the ratio as 3:27. Sorry guys. the wrenchman 11-16-2008, 03:55 PM Question: Who will be supplying the axle? ZF, Saginaw, Dana. Any schematics? prophet33 05-21-2009, 05:15 PM hmmm kind of a low gearing what do u guys think bout 4.10 gears jay_lt4 05-30-2009, 10:21 AM does anyone know the ring gear diameter on these? 8.8" HeavyChevSS 06-08-2009, 10:18 PM Does anyone make different ratios for this rear end. From what I remember reading the 3.45 and tall tires provide for 54mph in first gear, I would guess that a change in gear ratio would give a dramatic increase 0-60 and 1/4 ets. ???? jay_lt4 06-08-2009, 10:45 PM no aftermarket gears are made for this diff yet prophet33 06-09-2009, 10:17 PM they better hurry up one of the first things im buying gstan 07-27-2009, 08:32 AM Hey guys, is there a gear option for the M6? Is the standard a 3.45? Is an A6 a 3.27? Thanks for the help! | ||
